Question about Hyundai H700 Android 2.3 8 Inch Capacitive Screen Tablet PC Black
How to upgrade my Hyundai H700 from 2.3 OS to higher ?? OS it keeps freezing on Google+
My Nexus 7 tablet says no updates but is only running android 5.1.1. How do I get it to update to latest android version?
Hi if you're tablet is a 2012 model it will not work with the Android 6.0 marshmallow update......Go to Google search type in HOW TO INSTALL ANDROID 6.0 MARSHMALLOW on your Nexus tablet,..... Cheers
Jan 05, 2017 | Tablets & eReaders
Error 504 when trying to download facebook
Try theses steps:
1) clear cache and data for Google play and google mail
2) logout from Google and log back in
3) reset router
If these fail the only other fix is for the android OS to be deleted and reinstall. At this point unless you are very knowledgeable I would suggest contacting samsung for repair.
Jul 06, 2016 | Samsung Tablets & eReaders
I will like to up grade from a 4.1 to a higher grade.
There are many reasons why you cannot upgrade to a higher version of Android OS on an inexpensive tablet.
The main reason is that there is not enough memory to fit the newest version into.
It is unlikely that your tablet will take an upgrade.
Mar 14, 2015 | Tablets & eReaders
Can someone help? I have a Trio tablet. I am unable to access due to multiple pop ups that Google has stopped working.
try if you can delete all not necessary files from startup sequence, and if you can download upgrades for the system, if you can, upgrade to android 4.1.
if not then go to this site and try to flush it:
http://forum.xda-developers.com/showthread.php?t=1831257
have look at the flics and follow comments as well:
https://www.youtube.com/watch?v=ZcOqELRABDs
https://www.youtube.com/watch?v=QaGCIItG3NA
hope this will help you - do not forget to vote... by the way, i did find them on amazon for $45.00 new...
Feb 26, 2015 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
How to fix hard bricked Hyundai Hold X700 NoBluetooth tab?
you can format your OS and need to delete all application you use on your tab,you can format by go to your nearest hyundai show room
May 30, 2014 | Umi Hyundai Hold X Ultrathin 7 Inch IPS HD...
Zeepad still freezing i want to keep it, i just followed instructs in box, charged it, held power down for three minutes, and now recharging for two hrs. any tips, i don't like returning things i purc
Upon first use, you have to charge the battery overnight. Then for every recharge, you may have to keep it connected to the charger for at least 4 to 6 hours depending on your tablet, otherwise, your battery will go kaputt in a short period of time.
Mar 12, 2014 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
All of my google apps have "stopped" when I go to use them
You may need to upgrade the OS on your tablet. You could also try clearing the data for your google apps.
Jan 30, 2014 | Ematic 7" Tablet Computer
Ipad 1 os is erased
Connect your ipad to itunes then put it in recivery mode -1 turn on the ipad -2 keep holding the power button and the home button till the device turns of and then turns on -3 release the power button and keep holding the home button till u see and itunes photo on your ipad Now open itunes and restore
Apr 21, 2013 | Apple iPad Tablets & eReaders
Hyundai H700 Android 2.3 8 Inch Capacitive Screen Tablet PC Black Logo
77 people viewed this question
Top Hyundai Tablets & eReaders Experts
Are you a Hyundai Tablet and eReader Expert? Answer questions, earn points and help others
