Question about Lexmark E250dn Laser Printer
Lexmark E250dn , asks me to add paper but paper tray is full, where do i check for the sensors
    New Friend:
  • 38 Answers
There is a sensor relay arm under the body of the printer in the hole created by removing the paper tray.
Look for a long thin peice attached to a spring assembly.
There is a wire that plugs in to the relay it may be loose.
You might also remove the paper, push the metal peice of the paper tray into a locked postion and then replace your paper
Posted on Oct 11, 2013
4 Suggested Answers
xptareq2000
  • 1447 Answers
SOURCE: Lexmark c720 color laser printer
please chack it feed claught unite
thanks
Posted on Jul 31, 2009
thunderbo611
  • 75 Answers
SOURCE: Lexmark T630 paper jam 238 it says check duplex.
in the back
Posted on Jan 26, 2010
  • 21 Answers
SOURCE: My Lexmark E250dn is constantly having paper jams,
Check the paper feed path if everything is cleaned out and aswell your exit sensor.
If that dosent help clean you pick up rollers.
Also give me more details on more or less where it jams in the printer?
Posted on Nov 10, 2010
Need the windows 7 to recognize additional paper drawer for a Lexmark E250dn
Make sure to enable that under printer properties. Just go to Printers and Faxes > Right Click on the Lexmark icon > Properties > Configuration > Check Tray 2.
Nov 20, 2012 | Lexmark E250dn Laser Printer
The "add paper light" is on even though the paper
The light means that the printer is out of media, or the media did not feed properly
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
Jun 29, 2011 | Lexmark E232 Laser Printer
My Lexmark E250dn is constantly having paper jams, if I print more than 10 pages at a time I always have to stop and fix it, are there any solutions?
Nov 10, 2010 | Lexmark E250dn Laser Printer
My Lexmark E250dn laser printer is not picking up the paper to print. It sounds like it's trying then it jams up.
I had the same problem on my E250dn. First remove the paper tray. Shut off the printer. Tilt it sideways if it's manageable. Then, clean the 2 rollers directly underneath the printer with alcohol. That solved my problem and hoped yours as well.
Apr 19, 2010 | Lexmark E250dn Laser Printer
Says add paper to large tray even though it is full
Depending on which large capacity feeder you have.
If you have the one that is on the bottom of the machine, make sure there is a gap between the paper in the front and rear of the paper tray, There is a black plastic guide in the middle of the tray that may be being caught by the paper.
If you have the large capacity feeder on the right side of the machine then most likely the black actuator that tells the machine the tray is full has broken or the sensor is bad,
Feb 12, 2009 | Toshiba E-STUDIO 650 Copier
Lexmark e250dn
Over time the rollers get slick and hard. If one side is slick and the other edge is not, it will grab paper sideways and you get a paper jam. Get some rubbing alcohol and rub the rollers (completely all around) to get some debris removed. Some rollers require a slight rubbing with an abrasive pad.
Feb 18, 2018 | Lexmark E250dn Laser Printer
ADD PAPER
Check the upper limit sensors if they are moving nicely and freely check out put or simply swap the sensor with other tray. "Or try with dust blower/dust buster can" Good luck
Jun 17, 2008 | Panasonic Workio DP-2500E Copier
Lexmark E250dn Laser Printer Logo
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
