Printing error message 'completed with error(016-799):Print Instruction Fail detected in Decomposer
SOURCE: Print heads
I've had this problem on and off for quite a while now. I find the printhead problems are due to ink drying overnight and the printer cleaning mechanism failing to wipe it off (that doesn't work properly as the machine ages). An error comes up then that a printhead is 'bad'. I remove the printhead and clean it with a propriatory fluid (which is meths basically)and that cures the problem. However it is vital that after cleaning you wipe the printface and all the contacts dry, and I mean absolutely dry, with a tissue or similar. It must be totally dry or the error is reported again. I periodically give this treatment to all the printheads as the machine doesn't wipe them clean anymore like it did when new. Hope that is of some help.
Posted on Mar 30, 2007
hemantraj
  • 638 Answers
SOURCE: Incorrect Port Detected
  1. FIRST TRY TO CANCEL ALL THE PENDING DOCUMENTS WHICH YOU HAVE GIVEN BEFORE THEN TRY TO PRINT IF THIS DOES NOT WORK THEN TRY OTHER OPTION GIVEN BELOW.
  2. CHANGE THE USB WIRE (THE CONNECTION BETWEEN PRINTER AND YOUR PC )IF IT IS TOO OLD.
  3. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  4. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  5. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  6. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  7. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  8. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  9. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE
Posted on Jun 08, 2008
jim4984
  • 797 Answers
SOURCE: Unable to print or copy Brother MFC-440CN
Sorry for the very late posting of this solution. I recently had a problem with a MFC-440CN and bought a service manual. This is what is listed in the manual for this error:
Code: 8F
Symptom: The paper feed motor is being driven and cannot be stopped.
Probable Cause: Software malfunction
Solution: Open and close the scanner cover.
Unplug and plug the AC cord.
Posted on Mar 11, 2010
  • 1218 Answers
SOURCE: Printer: HP C4599 All in
I suggest you try to reset the printer. remove the cartridges before starting these steps.
1. Press the Power button and the Cancel button at the same time and release them. The display will show 'Enter Special Key Combo'.
2. Now press the Blue(Scan), Green(Color Copy) and Grey(Black Copy) buttons one after the other. The display will show 'Support
Posted on Oct 05, 2010
vonnielsen
  • 169 Answers
SOURCE: Officejet Pro L7590 print test
ALign the printer manually. TO to that follow these.
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Go to Printing Preferences 3. Click the Features Tab 4. At the bottom of the window you will see Printer Services or Device Services. Click on it. 5. Choose Align Printheads on the list.
Try Printing Again. I hope I was able to solve your problem. :)
Posted on Feb 06, 2011
Canon printer 6c10 error
Did you try IPA to clean the absorber then leave it to dry COMPLETELY. Also some printers have a small electrical connection to detect when the absorber is at capacity, check these contacts.
Oct 03, 2012 | Canon Pixma MP640 All-In-One InkJet...
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
Goodmorning, my hp t610 have message print head replacement not complete. I tried several times but the message is always the same. the print head are new!!! I look forward to a response. best...
Hello.
This error occurs when a print head can not be detected. Sometimes the very fine contacts that detect the printhead can become dirty with ink. Power the printer down, remove the heads and try cleaning the circuit contacts on both the printer and the print heads with alcohol wipes. Switch the printer on and replace the heads.
I hope this helps Regards GM
Apr 27, 2011 | HP Designjet T610 InkJet Printer
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Cartridge Error
Aug 13, 2009 | Dell A940 All-In-One InkJet Printer
Error 50 c
  1. Power off your printer.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Hope this helps.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
Fail to make our new fax machine work well
what are you asking? Work well? print quality problem? error message? My crystal ball is in the shop.
Mar 01, 2009 | Canon FAX-JX200
How to install a new printer
1. install the driver that include in a package of printer
2. read and follow instruction in the installer cd
3. after installation of driver complete..connect the printer,pc will automatically detect it{new found hardware} and wait for the message{your new hardware are installed and ready to use}
in printing select the model of the printer connected and installed before you print.
Sep 17, 2008 | Computers & Internet
Error code 50c
Cartridge Error 50C
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
May 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
Trouble code
Oct 23, 2007 | Lexmark X5150 All-In-One InkJet Printer
3,022 people viewed this question
k24674
jasbo
jasbo
