Question about HP LaserJet M1120 MFP All-In-One Printer
How to fix scanner error 22 with laserjet m1213nf mfp
Posted on Nov 21, 2013
manojro
  • 495 Answers
SOURCE: Scanner Error 12
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
Posted on Apr 17, 2009
haivanko
  • 37 Answers
SOURCE: error 6 hp laserjet 1120 mfp
The problem is that the motor that drives the scanner probably overheated and because of the cheap plastic that HP used it melted important points that the motor relis on...so - remove the glas of the scanner(there are some screws - one of them hidden under the label of the panel,unhook the interface cable of the panel).Now you should see the scanner - flip it over and look at the motor exle and the gear that it should mesh with - they are not aligned at this time.To fix it i used 2 small pieces of plastic - sticked it under the motor so that it can not move in vertical direction anymore. Simply this is the solution that i used and it works just fine :) If you have any questions dont hesitate to contact me. alpescomputers@winetbg.com
Posted on Jun 15, 2009
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Posted on Apr 19, 2010
seeker5211
  • 1089 Answers
SOURCE: scanner error 6 in hp laserjet m1120 mfp
Cable may not be connected correctly, try reconnecting the scanner cable. Or the scanning software is corrupted. Try uninstalling and reinstalling the software. Did your scanner ever work?
Posted on May 27, 2010
  • 8 Answers
SOURCE: ERROR SCANNER 22 EN IMPRESORA
REMOVE THE SOFTWARE AND FRESH INSTALL WITH THE DRIVERS CD
Posted on Dec 02, 2010
Scanner Error 22 Hp Laserjet M1213nf MFP printer
it is a physical broken piece that supports scanner mechanism. from what i can find. dont no if this has helped.
Jun 16, 2016 | HP Office Equipment & Supplies
How to solve scanner error 22 in HP laser jet 1213mfp
Perform a power reset.
Press the Power button to turn on the printer.
With the printer turned on , disconnect the power cord from the rear of the printer.
Wait at least 30 seconds. Reconnect the power cord to the rear of the printer.
update the firmware by download from this link: HP LaserJet Pro M1213nf Multifunction Printer Drivers
Jan 20, 2015 | HP Office Equipment & Supplies
Scanner error 22 i cant scan anything...
scanner strucked in a place disturb it by putting it in other place ,check the gear down to the scanner
Sep 05, 2013 | 2SToner HP Laserjet Pro M1213nf Printer...
Scanner error 22 HP laserjet M1213nf MFP
Update the firmware on the printer. I have included the url.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lang=en&lc=en&product=4075457&
May 07, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Scanner error 22 M1213nf mfp
why it is showing scanner error 22 message
Feb 23, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Modelo da impressora,HP laserJet M1120 MFP defeito... ao ligar a impressora no display aparece ..ERRO SCANNER 22..e nao scannea a imagem..... demais funcoes como impressao,aparentemente OK!
little bit I under stood your language, there is scanner error 22, remove flat bed glass, remove scan head, check mechanism observe any breakage, replace it mechanism, if no replace entire scanner head..see the test shot.
Sep 09, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Unable to resolve "scanner error
how can i resolve the error code 22 on my hp laserjet m1212nf MFP?
Jul 23, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Lazer jet M1120 MFP scanner error 22
Hey I'm using a HP LASERJET M1120 MFP. But every time I turn on the machine the screen says "Scanner Error 20". How to fix it up? Thanks!
Nov 03, 2010 | HP LaserJet M1120 MFP All-In-One Printer
SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
Feb 22, 2009 | HP LaserJet M1120 MFP All-In-One Printer
HP LaserJet M1120 MFP All-In-One Printer Logo
2,263 people viewed this question
Seeker5211
Seeker5211
