Codice errore f06 lavatrice indesit - Washing Machines
3 Suggested Answers
SOURCE: cosa significa il codice errore
la lavatrice mi si blocca con un codice F09 e poi dopo una diagnostica finisce in FA. Posso fare qualcosa per sbloccarla... si è rotto l'acquastop? Grazie
Posted on Feb 01, 2011
auro48
SOURCE: indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Posted on Sep 26, 2012
F06 error on indesit WD 61451 washing machine
Could be the program select error, but why not check all error codes and save them on the Indesit site yourself.
Error Codes Indesit Service
Feb 25, 2015 | Indesit Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Indesit model iwe7125b problem f06 what does it means?
F06 : DOOR LOCK fails to close/open, door lock triac open/closed, frequency signal fault.
Action: Switch off the device. Disconnect power. Wait about 3 minutes. Open the door, then close, reconnect device to the network. Start device
Dado
Dec 20, 2014 | Indesit Washing Machines
Errore f6 lavatrice ariston wmg 923
F06: Selector Error
Overhaul CND (selector connector)
Overhaul Selector Connector
Control Selector/CND Continuity
Control Selector Motor
Replace Selector
Replace Card
Dado
Feb 23, 2014 | Ariston Technologies Ariston AWD12 Front...
Errore f00 lavatrice bosch
Errore F:00 lavatrice bosch ecomaxx7 vario perfect
Jan 23, 2014 | Washing Machines
Indesit 123 FAULT F06
Sep 06, 2012 | Indesit W 123 Front Load Washer
Sulla mia lavastoviglie indesit de 74 evolution mi appare il codice di errore a12 mi sapete dire cos'?. Grazie in anticipo Fabio
Ciao Fabio.
A12 significa che c'e' un problema con il circuito di riscaldamento dell'aqua. A12 appare quando il modulo di controllo rileva che il circuito che include l'elemento e'aperto.
Elemento e circuito devono essere testati con il multimetro. Se l'elemento e' aperto deve essere sostituito. Se i cavi e l'elemento sono a posto, allora il problema e' il relay integrato nel modulo di controllo.
Il caso piu comune consiste in un elemento diffettoso.
In bocca al lupo.
G.
Dec 08, 2011 | Indesit 24 in. DE73 Evolution...
Cosa significa il codice errore F12-F09 in una lavatrice whirpool modello AWM8103/2
Jan 11, 2011 | Washing Machines
Errore F6
Errore F6 (F06) significa problemi con il motore, o con gli ingranaggi di trasmissione del motore.
La scheda di controllo della tua lavatrice rileva che il motore non sta girando alla velocita' richiesta o e' guasto.
Di solito , quando questo si verifica il tecnico controlla il motore, la trasmissione (motor coupling), l'unita di controllo del motore MCU (motor control unit), e sostituisce la parte difettosa.
Controlla questo link per avere piu dettagli su come risolvere il problema.
Non dimenticarti di votare la soluzione, possibilmente con quattro rombi azzurri.
Grazie.
Sep 03, 2008 | Whirlpool AWT5108 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
