Question about Durabrand DVD-1002 DVD Player
Says no disc
It will say loading, then its making a funny noise, like it doesnt want to spin normal, kinda like a spin then stop then go, and says thers no disc, i have tried different ones, it is a bit dusty inside, should i use alcohol to clean it first then go from there?
I have experienced the same problem. When I put the disc in I give it a spin in the clockwise direction. It works everytime!
Posted on Sep 30, 2007
SOURCE:
It will spin but the water does not come out, then it makes a funny sound-like a high rattle noise. We have never had any problems - we checked the hoses, they are clear. I has worked like a tip for years,...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Making noise when spinning
HI there.This sounds like the centre bearing & seal are worn causing noise & water leak.It's normally called a Hub & Seal Kit.It is quite an involved job & without the right tools it would probably cost somewhere around $300 upwards to have repaired.Very good quality machine & worth while repairing.Try to avoid useing the machine until repaired as you could cause electrical short due to water leaking.
May 28, 2010 | Speed Queen AWS44NW Top Load Washer
Washer made a funny noise, stopped working. I shut
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 13, 2010 | Maytag PAV2300 Top Load Washer
When you put a dvd in it tries to load but makes a funny noise then either says wrong disc or no disc
toooldie have you ever dropped your dvd player have you checked that your cd/dvds are clean if thif doesnt work go to a electronics centre they may be able to check it out for you i hope this helps
May 04, 2009 | Televison & Video
Wii makes a horrible noise while loading or ejecting the disc
Hello my name is Tim Ehrhart, I repair 360's and have had this problem with them and there problem is that the magnet that holds the disk in place gets stuck and makes a grinding noise that sounds horrid. Please leave feedback as I am new and trying to build a great rep. Thank You.
Mar 12, 2009 | Nintendo Wii Console
Psp3002 when the disc inserted, it made a sound
ok soyou psp made a funny sound when you were loading it up. hmmm i would say you might have a problem wit your disc reader. try other games and see if makes the same noise or doesn't make a noise it used to do like the high spinning revolutions the disc spins at. if it isnt moving then you need to get it fixed because your lense reader have probably shititself from things like smoke ashes or watrer or even heat.
Jan 01, 2009 | Computers & Internet
Washing machine
This deffenitly could be the brushes. Wierd sound normally comes from the electric sparking between the stator and the brushes. If it are not the brushes the best bet will be the bearing.
May 13, 2008 | Bosch Classixx WFO 2466 Front Load Washer
LOCK AND LOAD ISSUE
can you be more specific about the funny noise. When does it occur, during agitation or during spin? something might me stuck in the drain area of the tub and as the tub rotates it rubs against it.
Jun 28, 2007 | GE WSXH208A Front Load Washer
Durabrand DVD-1002 DVD Player Logo
148 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
