Meteor2 mc 4 driver - Televison & Video
2 Suggested Answers
  • 209 Answers
SOURCE: i need driver win XP for METEOR2/4 CARD
You will get drivers on this site www.driversguide.com
Posted on Oct 12, 2009
How do I change language on pioneer deh4600bt
Section
02
Using this unit
(iPod control)
c
This unit's iPod function is operated from your
iPod.
d
(Bluetooth indicator)
Set up menu
After installation of this unit, turn the
ignition switch to ON.
SET UP appears.
Turn M.C. to switch to YES.
# If you do not use the unit for 30 seconds, the
set up menu will not be displayed.
# If you prefer not to set up at this time, turn
M.C. to switch to NO.
Press M.C. to select.
Follow these steps to set the menu.
To proceed to the next menu option, you need
to confirm your selection.
LANGUAGE (multi-language)
This unit can display the text information from a com-
pressed audio file even for information embedded in
English, Russian or Turkish.
! If the embedded language and the selected lan-
guage setting are not the same, text information
may not display properly.
! Some characters may not be displayed properly.
1 Turn M.C. to select the desired setting.
ENG (English)-??? (Russian)-TUR (Turkish)
2 Press M.C. to confirm the selection.
CLOCK SET (setting the clock)
1 Turn M.C. to adjust hour.
2 Press M.C. to select minute.
3 Turn M.C. to adjust minute.
4 Press M.C. to confirm the selection.
En
FM STEP (FM tuning step)
Use FM STEP to set FM tuning step options (seek
step settings).
1 Turn M.C. to select the FM tuning step.
100 (100 kHz)-50 (50 kHz)
QUIT appears.
! The manual tuning step is fixed at 50 kHz.
! When AF and TA are turned off, the seek step is
fixed at 50 kHz even if set to 100.
5
To finish your settings, turn M.C. to se-
lect YES.
# If you prefer to change your setting again, turn
6
Notes
! You can set up the menu options from the sys-
tem menu and initial menu. For details about
the settings, refer to System menu on page 19
and Initial menu on page 23.
! You can cancel set up menu by pressing SRC/
OFF.
Basic operations
Important
! Handle the front panel with care when remov-
ing or attaching it.
! Avoid subjecting the front panel to excessive
shock.
! Keep the front panel out of direct sunlight and
high temperatures.
! To avoid damaging the device or vehicle inter-
ior, remove any cables and devices attached
to the front panel before detaching i
Feb 08, 2015 | Pioneer Deh-5400bt Car Stereo...
Clutch pedal goes to the floor but when i pump it it will come back
bad mc clutch
bad slave clutch.
can be either or both,
the hydralic clutch actuator has no adjustment other suz, older had cables, its no cable system as other states.
its auto adjusting
1: is Dot3/4 fluid leaking on either side of MC (clutch master cylinder)
2: is dot3/4 fluid leaking from the slave?
bingo fail for either leaking.
if no leaks the MC is bad, or not full of fluid.
3: does the fluid drop each weak, ( bingo for leaks)
Apr 14, 2013 | 2008 Suzuki Grand Vitara
How can i download the pc suite of lg optimus one
This link will open a guide for downloading manuals, PC Sync, USB driver.
Make sure you have Flash Player 10.2 installed to view the movie.
From this link you can download LG Mobile Support Tool. Click on the button as shown on the picture below.
Feb 28, 2011 | Computers & Internet
I changed the MC and bled it and still don't have brake pressure.
You must bleed the entire system starting with the wheel furthest from the MC....rear passenger side. rear driver side, front passenger side and then front driver side....
Feb 07, 2011 | 1988 Toyota Pickup
I need a driver for a matrox meteor2-/mc4 for windows 7.
There are no drivers availble from Matrox yet, you could try the Vista drivers, they should work.
Sorry that is all i can suggest!
Mar 11, 2010 | Matrox Meteor II (METEOR2/4) Video Capture
I need driver win XP for METEOR2/4 CARD
Oct 12, 2009 | Matrox Meteor II (METEOR2/4) Video Capture
No driver of pc camera mc 2pc
Go to retrevo.com. If you can't find it there you can't find it anywhere.
Apr 10, 2009 | Cameras
ERROR CODE C0096 - BIZHUB C350
2.6.19 C0096: Image Transfer Belt pressure/retraction failure
2.6.20 C0098: Fusing Pressure Roller pressure/retraction failure
Relevant Electrical Parts
1st Image Transfer Retraction Position Sensor (PC12)
1st Image Transfer Pressure/Retraction Motor (M11)
Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the M11 connector for proper connection
and correct as necessary.
2 PC12 I/O check PWB-MC PJ3MC-6B (ON) 6-B
M11 operation check PWB-MC PJ5MC-1~4
(Pulse Output)
6-C
4 Change PWB-MC
Feb 18, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
