Question about Sewing Machines
How do I engage patterns J-O (in red colors). It seems I can only use A-H (black colors) patterns
  • 130 Answers
If you have a red mark engrossed at your stitch length control, that should be the length of all your red patterns if not try set at maximum stitch length.
Posted on Oct 12, 2013
How do I fix the zigzag on the bernina 930
1. The switching pawl (lever on the top cover that switches from zigzag to cam patterns) may be engaged in the cam or automatic pattern side. Check that first.
For zigzag application, the lever must be engaged in the zigzag side (lever pulled back toward the operator). The stitch width dial is then used to provide your choice of width.
2. It is common, due to oil varnishes, that the switching pawl that is actuated by this lever is stuck between the zigzag and the automatic position, thus preventing the transmission of power to either the zigzag cam or the automatic pattern cams and to the needle.
The best way to detect this is to remove the top cover. You can then switch the lever back and forth to observe if the switching pawl engages firmly into either of the receiving forks. If the switching pawl is sticking, a few drops of certain solvents are applied by a technician on the switching pawl support. The switch lever can be rapidly switched back and forth until you see the switching pawl engage into the receiving forks and you hear a crisp clicking during each engagement. This repair can be permanent or it may create only a temporary fix due to the amount of oil varnishes on the parts.
If the machine is heavily varnished, it suggested that the parts be disassembled and cleaned for flawless performance. If the machine had been sprayed with WD-40, petroleum based solvents like mineral spirits will not break down these varnishes.
A caution regarding solvents...DO NOT USE (WD-40) as your solvent. WD-40 is a marvelous product for its intended application as a water displacement device. It is not to be used for lubricating a sewing machine. Note: "Bernina Technical Information bulletin #1" issued in 1982, forbade the use of such spray lubricants and solvents. SewTechnical Home
Oct 06, 2014 | Bernina Sewing Machines
Singer merritt 6125 pattern
Phone your local Singer shop.
Feb 25, 2014 | Singer Sewing Machines
When the machine is sewing with black embroidery thread, it will have big loops on either the top or bottom when sewing an outline and will also "nest" and the upper thread will break. Black...
Try a different black thread, quality can change a lot on threads. Also...black color is the worst for tension issues due to the overdying done to get a real dark black color on the thread. Looping on the top and the bottom are two different issues. Double check all threading when you have problems. Also the white is a brother pe100 clone. You may find a solution on a pe100 brother page or site.
Jan 15, 2011 | White Sewing W3300 Computerized Sewing...
Setting Machine on Different Stich Patterns
Turn the dial for stitch length so that the black line that separates the stitch length numbers from the buttonhole functions is in the 12 o'clock position. This engages the gears that operate your red stitches.
Aug 19, 2009 | Singer Electronic Sewing Machine
Bobbin on SE 350
Hi there, this seems to be a common problem with this machine. I have owned mine for a couple months now. The problem seems to be in the threading. The only solution I have found (and others on many forums) is to rethread the machine and the bobbin. I have also re-wound some problematic bobbins as they just maybe did not wind tight enough. Don't delete your patterns, that is not the problem. I have had proffesional patterns turn out a dozen times and then give me problems only to be fine once the machine decided it was threaded properly.
Feb 14, 2009 | Brother XL-3500
Bernina 707 Cam removal
take off the black metal bit that is above the pattern cam (4 screws). beneath you see 2 small screws, inside the metal frame, on each side of pattern cam. Take them out. Spin the pattern cam until you see one screw in the cam itself. Take that out too. Now you can push the splint out which holds the cam.
Apr 16, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
