Question about Delphi Throttle Position Sensor Chevy Olds Savana Suburban Ss10382
Throttle position sensor oldsmobile - Delphi Throttle Position Sensor Chevy Olds Savana Suburban Ss10382
  • 66 Answers
The throttle position sensor is always located on the throttle body itself
Posted on Nov 10, 2013
Where is the tps sensor located on a 96 Oldsmobile cutlass ciera
On the throttle body ! 3.1 or 2.2 l engine ? Throttle Position (TP) Sensor
Top of engine, on Throttle Body Assembly ! do you know what that is ?
Aug 01, 2015 | Oldsmobile Cars & Trucks
Replace throttle position sensor
the tps could be the problem, use a scanner to check it before replacing it
Sep 01, 2013 | Oldsmobile Cutlass Supreme Cars & Trucks
Tps location
Usually located opposite side of throttle body from the throttle cable
May 19, 2013 | 1990 Oldsmobile Cutlass Ciera
Throttle on 2000 oldsmobile bravada is stuck wide open
replace throttle position sensor then reset computer.
May 05, 2011 | Oldsmobile Bravada Cars & Trucks
Where is the throttle position sensor located at
On the throttle body. Look for your throttle cable and you can see where it moves the throttle cam when you push on the gas pedal. There is a rod that goes from there and through the throttle body to the other side. There you will see the throttle position sensor.
Jan 15, 2011 | 2000 Oldsmobile Intrigue
Where is the throttle body sensor located?
If you are talking about the "Throttle Position Sensor" you sort-of answered your own question. It is located on the throttle body on the oppsite side of where the throttle cable connects.
Jan 10, 2011 | 2001 Oldsmobile Alero
How do I install throttle position sensor on 2001 oldsmobile alero
I have a 2004 Alero ( similar procedure in your model as well ) and I just figured out today and replaced my throttle position sensor. I'm not sure what the black plastic "box" is called that is above the throttle assembly...but I had to remove that to get to the throttle position sensor underneath. If you can locate the two wires that control the throttle assembly...then the throttle position sensor is on the other side of the throttle assembly. I had to remove the large tube that went from the air filter to the black plastic "box" above the throttle assembly. Also disconnected anything else connected to that black plastic "box". Then pulled that "box" up and right there on the left side of the throttle assembly was the throttle assembly sensor. Here is a web page with a picture that helped me figure out where it was :-
http://en.wikipedia.org/wiki/Throttle_position_sensor
http://www.ehow.com/how_4590680_replace-throttle-body-oldsmobile-alero.html
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 10, 2010 | Oldsmobile Alero Cars & Trucks
What is the code 22 in my 1990 eighty eight olds
Code 22 is a Throttle Position trouble code.
Either the throttle position is not returning to home position, or more than likely the Throttle Position Sensor (TPS) is worn.
The throttle is at two positions most of the time. Either completely closed (not driven) or slightly open while driving. The slide wire will eventually become worn and give faulty readings to the computer, eventually causing the fault code.
The sensor is easy to replace and costs about $45.00 at Autozone or O'Reilly's.
Please let me know how I may assist further
May 19, 2010 | 1990 Oldsmobile Eighty Eight
Where is the throttle sensor located on a 2001oldsmobile aurora
Throttle Position Sensor is on the back side of the throttle body. Manual says to remove the EGR valve, then remove the two bolts holding in the TP sensor.
Mar 26, 2010 | 2001 Oldsmobile Aurora
WHERE IS THE THROTTLE POSITION SENSOR ON A 1999 ALERO
b693539.jpg Bolted to the side of the throttle body.
CLICK HERE to see a generic picture with the sensor mounted on the right side.
Theres a black plastic "box" above the throttle assembly...
Remove that to get to the throttle position sensor underneath.
If you can locate the two wires that control the throttle assembly...then the throttle position sensor is on the other side of the throttle assembly. Remove the large tube that goes from the air filter to the black plastic "box" above the throttle assembly.
Also disconnected anything else connected to that black plastic "box". Then pull "box" up and right there on the left side of the throttle assembly is the throttle assembly sensor.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 31, 2009 | 1999 Oldsmobile Alero
Delphi Throttle Position Sensor Chevy Olds Savana Suburban Ss10382 Logo
48 people viewed this question
Top Delphi Car Audio & Video Experts
Billy Mac
Lawrence Oravetz
Jeremiah Meyer
Jeremiah Meyer
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
