Hi I have my hp g60 laptop why if I turned it on it shows that. It will be work then a few second will be restart. It try and try again. Icant go in my windows.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 22 Answers
Do you have the factory system disk...you most likely have a virus nothing else really does this only other thing it could be is you have installed to many things and don't have enough ram or hard drive space for normal operations. try turning on and as fast as you can select system restore to a previous date. or you can factory clean system which is harder to find in such a small amount of time
Posted on Oct 11, 2013
patelsarju
  • 3 Answers
SOURCE: hp-g60 wireless problem
if your wireless lan driver not install in your leptop then it's not going on so re install it then try it's going to on orchack your lan if wifive is disabal then also not going to on you have to enebal it your wifie is working soon
Posted on Apr 28, 2009
  • 1602 Answers
SOURCE: SCREEN DOES NOT SHOW HELP HP G60
TRY HOOKING AN EXTERNAL MONITOR TO THE LABTOP IF YOU SYSTEM IS EQUIPED FOR THAT TYPE OF USE., IF YOU DONT HAVE ONE, SEE IF ANYONE YOU KNOW WILL LET YOU BORROW UNTIL YOU CAN SOLVE THE PROBLEM WITH YOUR MONITOR.
ROD
Posted on May 12, 2009
FoxSysPCTech
  • 107 Answers
SOURCE: HP Pavillion dv9005us screen stays dark
Lets start with the power, make sure it is charging by looking at the ring on the side that lights up when the power cable is plugged in. If this is on, then make sure the light on the front of the laptop is on. If it is charging and it is detecing power(2 lights will be lit) then you are okay with power. If the lights are not turning on, then it might be your charger. This is rare, but its worth a try. Get your hands on another identical one. Make sure the Watts line up or else you might blow something out. If it is not your charger, then it is probably an internal part such as the power plug or the motherboard. In either case, unless you really know what you are doing, then you would simply need to replace these. Before you order a new one online, keep reading.
[skip this part if your power is not working]
Pull out one stick of RAM, then try to start up. If this doesnt work, then try the other stick(put the first one back in). If that doesnt work, then try the hard drive. If this doesnt work, then try the wireless card an any other attachable devices(that connect directly to the motherboard). If this does not work, then the problem is in your motherboard and you will probably need to replace it.
[If your power is not working and/or it looks like you need a new motherboard, read this]
Be sure to contact HP first, they are doing a recall or as they call it a "service enhancement" to some of their malfunctioning laptops that are having motherboard issues. You might want to research what the service enhancement covers first. This will be important when dealing with the representative. Also make sure you try a lot of things with fixing it, even if it seems rediculous such as cleaning out the fan. The more it looks like you tried to fix it, the more likely they are to service your laptop under the 'service enhancement'.
Here is more info on the service enhancement. Be sure to read as much of it as possible. Sometimes the representative on the phone will try to say it isnt covered beucase it doesnt match the symptoms exactly. Try to show them as much as possible that it does fall under one of the defects listed and they will most likely fix it. This is a one time shot though, be sure you dont screw it up!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&dlc=en&cc=us&product=3439691&lang=en
Posted on Aug 04, 2009
  • 284 Answers
SOURCE: hp g60
it my be overheating if the fan isnt working
Posted on Dec 13, 2009
SOURCE: My Hp g60 laptop battery is not working
hai,
i think the problem in battery so try to get new battery and follow the tips to prolong u r battery life through nbbatt blog
Posted on Apr 01, 2010
New batteries won't charge
it needs service,
if the charge circuits fail, it needs to be repaired.
do know the charge chip is on the MOBO. so , not easy to fix.
https://h30434.www3.hp.com/
the full service manual is at HP, why ask here. we are not HP.
here it all is. see guides?
https://support.hp.com/us-en/product/HP-G60-200-Notebook-PC-series/3837658/model/3860166
my guess is the MOBO is bad,(the charge chip blew out)
Jun 01, 2017 | HP G60-235DX Notebook
Hp g60 will not turn on
Remove the battery. Keep pressed on power button for 30 seconds. Reinsert battery. Try again. Check with another charger (SAME SPECS ON CHARGER). If it does the same have in checked in service
Feb 05, 2013 | HP G60 Notebook
My HP G60-120US 15.6" Widescreen
Update and refresh the drivers.
click on start icon, type"device manger" and click on image viewer on the drop down right click on it and update the drivers and see if it is working,
If not then right click and uninstall and restart the computer and try to use if not post back.
Hope this helps.
Cheers!
Nov 24, 2010 | HP G60-120US Laptop
HP G60-235DX keyboard not working at all
Try to press Fn + Num Lock or Fn + Scrl lock to check if they keyboard will respond. If it doesnt. try to turn off the computer, remove the cables and battery, press/hold the power button for 8 secs. Reinsert cables and battery then turn on the pc. Press again Fn + Num Lock or Fn + Scrl lock. If the keyboard still did not respond, go to the device manager . Click Start > right click My Computer > Properties > Hardware > Device Manager . Then click the (+) on Keyboards, right click the device and uninstall it. Then, go back to the device manager and right click Keyboard then click Scan for hardware changes. Then press FN + Num Lock or Fn + Scrl lock. If symptom persists, call HP to replace your keyboard.
Aug 22, 2010 | HP G60-235DX Notebook
Grey screen but everything else works as normal Initially, on the windows startup (Bios) and the welcome screen, the colour is fine, everything is there. But after a few seconds logged in, everything turns...
That sounds like a problem with your GPU, this is very common with Nvidia graphics cards when built onto motherboards for mobile devices. First contact HP to see if you have any warranty with them, if not then you can either look for a company that specialises in board repair in your area or if you are brave try a DIY fix. Search 'motherboard DIY reflow' on google or youtube to see an example. Hope this helps,
www.PuterCare.com
Jul 21, 2010 | HP G60 Notebook
I bought my hp g60 in dec. 2008. and from d second day, its touch pad hangs up after using for few mins. than it works again when it should b restarted. and whenever i use voice or video chat than it...
The touchpad issue is linked with the converter which is loacted just below to your touch pad. When you use the laptop for some time it heats up and touch pad hangs( you might be feeling the heat) and the solution is to get it changed.
The voice breaking is all because of your internet connection.
Thanks
Apr 05, 2010 | HP G60-127NR Notebook
Hp-g60 wireless problem
Apr 28, 2009 | HP G60-120US Laptop
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
