Question about Porter Cable Air Tools & Compressors
Crank bearing cap blew out on Porter cable air compressor
Porter cable two cylinder D22629 air compressor pump blew out the crank bearing cap. Obviously a pressure buildup in the crank case but what causes this and what do I do to fix it ?
    President:
  • Porter Cable Master
  • 1,388 Answers
Your compressor is sold under various part #s depending on brand name. The link below is the breakdown for ac-0171.
http://www.devilbissparts.com/OilLubeStat%20PDF%20files/ac-0171.pdf. You will notice that there is no vent to release internal pressure. Most brands have a filler/dipstick which is also a vent. As the compressor wears there is a normal increase in crank pressure caused by pressure passing thru the rings. I have seen home made vents installed on the bearing cap. If you are creative you can make one yourself using the same cap or a metal cap (axel bearing cap) that fits the opening. A crankcase vent is a very simple device. A small hole to atmosphere with a bit of oil resistant foam behind to prevent oil from being blown out the hole. Works best when there is a vent tube about a couple of inches long to catch any oil and allowing it to run back down into crank. Remember that there is oil sloshing around inside the pump. Examine several brands of compressors for vent and try to recreate that on yours. One thing in common about vents is that they are usually located pretty high up above the crankshaft. You could also try lowering the cut-out pressure on your compressor to reduce back pressure. Good Luck on your repair.
Posted on Apr 23, 2009
C2002 porter cable air compressor will not build air pressure
I found this it might be helpful>.Your check of pulling the line off to the tank and seeing how much pressure is being generated is a good one. You have now pretty much isolated the compressor lack of pressure as being upstream of that point.
I would pull the intake filter too, and do the same check. Is it pulling air in strongly, or is it huffing air back out too? If huffing, that's a sign that the intake valve is pooched.
If it is pulling air in, and air is not being pumped out, yup, it could be a sign of cylinder piston ring wear, but then, you would be getting a lot of air out of the oil fill cap which is vented.
If that isn't happening, and you are getting strong suction at the intake, my money would be on an internal pump gasket blown which is allowing air to flow around inside the pump from high pressure to low, but not down into the tank.
When you open up the pump, you might as well have a new valve plate and gasket kit, as both are, in time, wear items inside the pump.
Sep 01, 2013 | Porter Cable C2002 150 Psi 6 Gal...
How to remove muffler intake from Porter Cable CPF6020-1 air compressor
To remove the air filter intake muffle you will need to remove the 4 screws that hold the head on to the pump.
There is a O-ring under the head you will want to put a little vasoline on before you reassemble the head back to the pump.
The new muffler kit should be the KK-4981
Sep 10, 2012 | Porter Cable Air Tools & Compressors
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Sources of noise from craftsman oil free compressors (could be Made by Campbell Hausfeld or Porter Cable) include loose fan, failing bearing/s on the piston rod and housing, failing seal ring on piston, air filter intake and loose motor mounts. With the housing cover off, check the fan blade for cracks or loose screw. Turn motor by hand till the piston is at top of stroke. Examine the cylinder for scratches close to top. If scratched, air is leaking past vinyl ring making noise and causing longer fill time. If everything looks ok, suspect noise coming from bearings. Hard to tell if bearings are failing by looking at them. I have seen many failures of the piston bearing on the crank (fairly easy to change, I use alternator bearing from auto parts ) , however, the bearing in the housing just behind the crank bearing is much harder to replacable. Good luck with your fix-it project.
Jun 11, 2012 | Craftsman Air Tools & Compressors
How to remove crankshaft for campbell hausfeld compressor
I assume you have removed the valve head-valve plate-cylinder assembly from the base and pistons. Remove the four bolts holding the bearing cap assembly on one side of the crankcase and remove the cap. You have to pull on the crank to get the crank bearing out of the opposite side of the crankcase. Move the crank forward and turn it until the rear bearing will clear the crankcase and the whole thing will tilt and come out the top. Campbell sells the entire crank, con rods, pistons & rings as an assembly under part number VT040600AJ. This is the best way to go as they don't have con rods to go on the crank if you were to get the journals turned down. NOTE: During reassembly, the bottoms of the cylinders have a taper so you don't need a ring compressor to get the pistons in the cylinders. Just be sure the oil rings are in properly before pushing the cylinder all the way down. The thin oil scrapper rings have a tendency to fold over and get caught between the piston and cylinder.
Jan 29, 2012 | Air Tools & Compressors
Compressor was running and made a loud "pop" and
Take a close look at the top of the cylinder and see if it is pitted or scratched. Usually the cylinder will cause the ring to blow backwards if there is too much clearance or pits. If however the cylinder is smooth, then you must have factory defect. Even if out of warranty, email the company for help. If no joy you can replace the cylinder /piston for about 40. dollars. Order parts from www.chpower.com. Other brands use this type of cylinder including porter cable, craftsman, coleman, ridgid, most oil free type of units. The porter cable units do have only the plastic ring available, however it is very short lived is the cylinder is even slightly worn. Good luck.
May 28, 2011 | Campbell Hausfeld Air Tools & Compressors
C2006 Type 4 Porter Cable will pump from 50# to 100# then will not pump any higher but will keep running.
This sounds like the piston ring is worn out and will not allow the unit to pump up to it's shut off pressure.
You can order the D30324 cylinder/ring kit and it should repair your problem.
You can order this at www.allpartsinc.com or go to www.msservice.net
Nov 06, 2010 | Porter Cable C2002 150 Psi 6 Gal...
What is the torque specs for a cylinder head for a craftsman air compressor 150 psi 7hp 60 gallon
The spec is 25-30 ft lbs.
Here are the specs.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D22629/d22629.pdf
Oct 10, 2010 | Craftsman Air Tools & Compressors
Rod seized to crank mod AM 78 Hc 2
The best way to explain it is with a diagram. At least it is for me.
If the image is to small just click the link below it.
This is for a D55150 compressor pump. However it should be the same as yours.
If the diagram isn't enough please let me know and I'll try and talk you through it.
The second link is for parts if available.
Hope this helps.
http://www.mastertoolrepair.com/images/D55150_pump.jpg
http://www.mastertoolrepair.com/d55150-type-pump-parts-p-21200.html
Dec 27, 2009 | Dewalt d55151 factory reconditioned emglo...
I need to replace the connecting rod,cylinder sleeve,and eccentric bearing assembly on a craftsman model no. 919.165050
Your compressor is made by Porter Cable. You can use sears parts or takes your old parts to a local Dewalt service center and they will match them up with replacements. You can save some money on the bearing by using a generic. Universal bearing number will be found on the dust shield. Most likely the sears part numbers will be the same as porter cable. Dewalt service center will help you with other questions and or instructions. Good Luck!
Oct 10, 2009 | Craftsman Air Tools & Compressors
Air comp bad crankshaft and rods need to remove and replace
What type of air compressor do you have?
Is it a single motor\pump combination is the pump and motor separated by a fly wheel? If it's the first one don't waste your time or your money. Hard to find parts hardier to justify the money if you do.
If it's the second then you should make sure you can get a rebuild kit and replacement parts. If you haven't already.
Assuming you have anyone of the more common pump brands like Dayton, Champion, Ingersoll Rand.
Dis-assembly should start with the top end. Remove the head and valve plate then the cylinder head bolts and cylinder head. Remove the wrist pin\pins and piston\pistons. Next remove the lower rod end caps and pull them out taking care not too nick the crank bearing journals. Remove the front crank cover and and (if it has one) the rear bearing cap\plug. You should be able to remove the crank through the front access. You may need to tap the back end of the crank clear or the rear bearing.
The bearings will probably need to be pressed out.
Unless you have a pump that is considered non serviceable or is an oddity this should do it.
If your pumps layout differs from the norm or you just need more specific information please let me know. Just include the make and model and I'll be glad to help you out. Good luck.
Aug 25, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
212 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
