Question about HP Pavilion dv9500 dv9600 and dv9700 FF Athlon Motherboard - 450799-001
Hp pavillion dv9700 has black screen on start up followed by 1 long and 2 short beeps and then fan turns on loud and for a long time keeps at it and then windows sound turns on and then blindly i place my password hit enter and sounds as it enters properly but at all times screen is black and no led lights either. This problem happened after I downloaded microsoft fixes for freezing screens and computer crashes but at least I had led light on the back and always could eventually turn the screen on but not any more after these downloads. Is there a way to reverse this without a screen? I tried connecting with external screen but there is no signal.
    Top Expert:
  • HP Master
  • 78,267 Answers
I think the mother board has failed.
Posted on Apr 05, 2017
Kwitch
  • 33 Answers
SOURCE: start up problem
Hi Irmf,
Generally, that loud beep you hear is your BIOS (the part of the computer that turns on everything else) alerting you that there is a serious error with it's ability to function. Just for example, the beep could be due to your RAM not being properly seated, your BIOS being damaged or missing, your Hard Drive not being detected, or a non-system boot disk being inserted.
So troubleshooting that particular problem sounds tricky. But I do have a few possible repairs you can attempt that would at least let you know why it is making these error beeps, and go about seeking repair assistance.
1: Remove your RAM from your unit. On the bottom of your computer, you will find one or more small covers that are easily enough unscrewed to allow you access to some of the internal parts of the machine. Underneath one of these panels will be (usually) two thin white slots arranged either back-to-back or stacked as a staircase one on top of the other. These are the DIMM slots for your computer, and should contain your RAM (the green small rectangular circuit boards that contains your your temporary memory). You can release the pressure release on both sides of each stick, and lift up gently to remove the sticks of RAM. The RAM is removed and replaced by inserting it firmly into the DIMM slot at approximately a 45 degree angle. You may only have 1 stick of RAM, but what you need to do is alter the configuration of what you have. Such as: Remove both sticks of RAM if you have two, then only place one into the machine and attempt to turn on. If it does not turn on, repeat by removing the 1 stick and replacing it with it's sister stick. Test and see if it works / shows any improvement. If you have 2 RAM sticks, one might be bad and you can determine if it is by testing both and eliminating each as working or not.
2: If removing your system RAM and replacing it firmly into your unit does not chance the condition at all, next I would suggest attempting to connect an external monitor to the laptop and perhaps producing a video output. Your laptop should have a VGA connection (usually blue, has approx. 15 pins, and is shaped like a trapezoid). Also, your laptop should have a Function key (the F-numbered keys on top of the keyboard) that enables you to switch the video output from the laptop screen to an external CRT or LCD. Usually this is F4, F6, or F8. It should say CRT/LCD or have an image of two rounded squares on it, in blue painted decal, underneath the F-1-12 part of the key.
This might allow you to determine that your screen is bad, and perhaps it will mention why. Lots of possible error messages with that, if it works at all.
3: You can remove the casing from the laptop if you are very careful to notate where each screw is removed from so that you can re-assemble it afterwards. Locate the CMOS battery on the motherboard (it looks like a larger, flat, watch battery). If you remove this, and place it back into the motherboard, you can often cause your BIOS to reset (potentially removing an improper BIOS setting or update).
Otherwise, you are limited to what you can do yourself without the use of full technical manuals and equipment to test the integrity of individual components in the laptop to figure out why it won't post at all.
My personal guess, is that it is a motherboard issue, but saying 'it's a motherboard issue' without attempting some troubleshooting first is almost a cop-out if you're a tech. If it has a warranty, I would suggest having HP repair/replace parts on it under your coverage rather than attempt to solve this yourself, but the steps I've outlined are to the best of my knowledge how you would eliminate possibilities that could be related to your error and no display.
Sorry for the length of the post, but I hope that helps!
Posted on May 04, 2008
Whisperwolf
  • 110 Answers
SOURCE: HP Pavillion dv9000 - won't power up
There was a major problem with my old HP Pavilion, so major in fact that HP replaced it entirely.
IF you can get your laptop started, then try updating the firmware by going to hp.com and navigating to your particular model. The update you're looking for is BIOS Firmware.
If your laptop is still under manufacturers warranty, then yes, this IS a known problem, and they will send UPS to your door with prepaid packaging to return it to them. They are starting to catch up with the backlog but it seemed to be a frequent fault in the earlier versions. Happily they seem to have fixed it in later notebooks.
If you need the software or data from it, you will have to take it to a store who can remove the hard drive and copy the data off it. Where I live, in Canada, Future shop did that but it cost me $70. Unfortunately there is no guarantee if you bundle your notebook off to HP that they won't simply replace it, so weigh up whether the data on it is worth paying a fee to back up before you send it off.
Posted on May 26, 2008
WeListen2You
  • 538 Answers
SOURCE: Blank screen, led lights on, intermittent beeps
sounds to me like the battery may be at the end of it's useful life..usually around 2 to 3 years..
Posted on Oct 22, 2008
  • 916 Answers
SOURCE: Screen goes black after windows XP logo, then no response.
I would suggest checking your hard drive to see whether or not it has a bad sector on it.
Posted on Dec 20, 2008
SOURCE: HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Posted on Jan 19, 2009
HP Pavillion dv9700 will turn on but the hard drive light will not blink and the screen is blank
You may be able to rescue it with a Bios flash, but it sounds like your motherboard died.
Jun 30, 2012 | HP Computers & Internet
Hp bricked after bios updates hp pavillion dv9700 need help please
hello,
this indicete that you did not do properly the update,my advice is to restore the old bios if you backed up if not try to do again the update
Jun 12, 2012 | HP Computers & Internet
What might be the cause of hp pavillion dv2000 not displaying on the screen at start up and giving 3 beeps, 1 long and 2 short, sometimes it boot but doesn't get to the desktop area?
1 long beep followed by two short beeps is usually indicative of a failed/failing display adapter. On something as.... rustic as your dv2000 it can be fixed.... but probably would see better value from just replacing the unit.
Oct 23, 2010 | Computers & Internet
I have HP Pavillion dv9700, it continuously turn on and off every seconds and no video. It will only start if you press the ESC key but no video but indicator lights are on and the cpu fan is running and...
try resetting the bios to factory from the info u have given not much can be assertained so please provide much much more detail next time with the problems your describling though i would also recommend taking it to a repair shop
Oct 01, 2010 | Computers & Internet
Computer will not come on loud sound from pavillion repeats it self. The fans will spin and the blue light on pavillion comes on. moniter screen will not come on the power light is on
On some computers, when you turn it on, the fan starts to run at 100% of its speed, i.e., very noisily.
Then, when it is detected that the computer is functioning, and _not_ over-heating, the fan will slow down, and quiet down.
So, what is the nature of the "loud sound" ?
Continuous? Beeps, in some pattern?
Take the computer to a qualified technician, for better trouble-shooting.
Jun 09, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
When i turn the computer on it beeps three times very loud and the screen stays black
your memory is bad and it needs changin or you could just download the bioflash program from hp and i should work from there
Feb 08, 2010 | HP Pavilion dv6000z Notebook
Laptop Beeps on start up 1 long and two short beeps
You've checked the memory board/card, but have you tried using another memory card? The 1 long followed by 2 short beeps indicates that there's a problem with the memory card. Try to remove the memory card, then wipe the gold traces with a dry cloth and put it back in.
If you try replacing the memory card but you get the same problem, then proceed with the video card.
Aug 29, 2009 | HP Pavilion dv9000z Notebook
Black screen and 3 loud beeps when starting up and recharge light off when charger is connected.
1/long beep followedby 3 sequential short beep- graphic card problem2/shortbeep followed by three sequential long beep- system memory problem thanks
Jul 12, 2009 | HP OmniBook XE3 Notebook
HP Pavillion dv5 startup problems, no screen 3 beeps in loop
Hi, you need do follow things:
1) check RAM in the back small cover of laptop, clean RAM pins and slots set back or change RAM position each other ,or replace other RAM(same model) if old RAM not works.
2) take out the wireless card in the back small cover that is MINI PCI slot, then turn on. sometimes it cancause this trouble.
help you fix it, and any question keep in touch please.
May 14, 2009 | HP Pavilion dv5-1000us Notebook PC
HP Pavilion dv9500 dv9600 and dv9700 FF Athlon Motherboard - 450799-001 Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
