Kenwood 103sw single rca jack ouput,subwoofer has 2 inputs,left & right
    New Friend:
B I
Posted on Oct 11, 2013
5 Suggested Answers
SirHanz
  • 145 Answers
SOURCE: subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Posted on Jan 29, 2008
djnick989
  • 1067 Answers
SOURCE: DCM SUBWOOFER PROBLEM.
telll sterio use sub out and remix on in settings menu on steiro ok also does it have speaker wires in and out use them off fornts ch from sterio then back up throw sub to fronts set cross over on 100 or so
SOURCE: indicator light not working and humming noise
your circuit board is bad not repairable i have the same prob but not kenwood they said it would cost more then its worth.
Posted on Mar 31, 2008
SOURCE: connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Posted on Jan 07, 2009
    Hooking up a dual line in from a single line out
    I would recommend a run to Radio Shack and buy a RCA splitter, I have one that does 1 rca to 2 rca's. Just check what type of ends you'll want for both sides as in male or female. God bless, hope this helps.
    Dec 23, 2013 | Yamaha YST-SW160 Subwoofer
    What kind speaker use my kenwood powered subwoofer 103SW
    It uses a 10 inch, 4 ohm speaker, probably rated at 100 watts. If you are getting no sound, check your connections. Or, the subwoofer amp may be blown.
    Aug 29, 2010 | Kenwood 103SW Speaker
    Subs not programmed into dash...?
    It sounds like the input gain on the amplifier needs to be adjusted.
    OR if your certain this hasn't changed see if both of your RCA cords (Left and right) are working. I had a similar issue when the mono block AMP was only sending signal from the left channel to the amp which in turn was dropping the input load in half. Its all about isolation.
    Simple way to test this is to adjust the L/R balance of your deck all the way left or right and see if the amount of bass changes. If you balance all the way left and you lose your base completely then you know your amp isn't getting signal from the left channel thus if you move it all the way to the right and the bass disappears then the problem is with the right channel.
    Jul 05, 2009 | Kenwood 12" 4-Ohm Single-Voice-Coil...
    Which jacks to wire the subwoofer to?
    Your receiver should have an RCA connector on the back panel that will be marked "sub woofer" or "LFE out". That connects to your sub woofer with a standard RCA type cable. Also, some powered subs have left and right speaker level inputs and outputs in which you would indeed run the sub woofer through the speaker outputs. The down side of that type of connection is that the line level converter inside the sub woofer will take a slight amount of your receiver's output power, although that is rarely detectable. Also, if you have a Dolby Digital receiver, using this connection method will take away systems ability to accurately control the low frequency effects of a soundtrack.
    Good Luck,
    BB
    May 16, 2009 | Kenwood Audio Players & Recorders
    Cant get bass, fuse is fine
    You don't say if you've configured the Receiver to know you have a subwoofer (under Multicontrol - SUBW YES). Unless it knows about the Sub it won't send anything out that single "preout". You can get an RCA splitter to run that single output to both inputs in the Sub.
    Just as an experiment, temporarily run one a pair of cables from the REC OUT to the Sub's inputs and tune an FM station to prove the Sub amplifier is alive. If it's still silent, it's dead. If there is sound (muffled) you need to go back to the Receiver to figure out why the Sub Preout is signal-starved.
    Need help hooking up a KRK powered subwoofer to an Onkyo 7.1 receiver
    a single male rca spliting into 2 male rca's ....a signal splitter
    Oct 30, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
    Kenwood KDC-X590 CD Player
    what do you mean by one set is a hard wire and other is an rca jack?the hard wires go to the speakers and the rca is wired to an amplifier of some sort which is wired off to more speakers or subwoofer(s)
    Aug 12, 2008 | Kenwood KDC-X590 CD Player
    How to connect a kenwood powered subwoofer to a 7.1 onkyo receiver
    Easy.Get a 2 into 1 rca lead and plug the single end into the receiver and the other 2 into the amp
    Jun 08, 2008 | Kenwood DNX7100 Car Video Player
    Indicator light not working and humming noise
    Jan 03, 2008 | Kenwood 103SW Speaker
     Grubhead
    Grubhead
