Question about Timex 5B841 Wristwatch
Replacement wristband for Haurex Black Mamba watch
Where do I send my Haurex watch for repair?
sadly they probably will not take it back, perhaps send in for repairs .
Sep 12, 2016 | Haurex Watches
Hello, i purchased a Haurex Maestro watch last year. i believe that it is a mechanical watch but i've had issues with the watch stopping. i was wondering if someone would be able to assist and let me know...
i just bought one last week and having the same problem. I have an accutron automatic watch and once i get it started it will keep time for up to 48 hours w/ no movement. I think the haurex is poorly made and if i can't get it to run longer than 12 hrs( wichi is about how long it runs now) i will be returning it.
Feb 22, 2011 | Haurex Maestro Mechanical and Chrono Watch...
I have the Haurex Italy Promise Women's Crystal Watch. I bought it in June of this year. The watch stopped running today. This may not be relevant but I do not wear a watch very often, keeping it more...
It is unusual for a quartz watch to stop so soon (presumably the battery is now dead?).
I suggest you contact the makers local customer care center and discuss it with them.
You can find their local service center by going to http://www.haurex.com/collezione.asp?id=93 and clicking on "after sales service". If you have any proof of purchase date, then it should be still under warranty if it needs repair.
Dec 16, 2010 | Haurex Watches
I need to know how to put on a Haurex watch using it's intricate band
pull the small loop on the end of the metal clasp. place the other strap through the loop and snap closed. fold one end of the clasp shut then the other.
Aug 07, 2010 | Haurex Italy San Marco Chronograph Watch...
The haurex emblem in the watch is loose. how to fix it? repair wathman said you will have remove crystal to fix instead of going in from rear.
This is completely wrong. You HAVE to open watch's case back, remove the stem and then get whole movement out. Then you will be able to refit emblem. Rate me, plz.
Mar 17, 2010 | Haurex 1r320un1 Armata Watch for Men
I just bought a Haurex watch with the white rubber band and I can not get the clasp to work.
Go back to the supplier; If you cannot get the clasp to work, you should be shown how to operate it (or it should be replaced if it is broken).
Dec 31, 2009 | Haurex Italy San Marco Chronograph Watch...
How to replace the rubber wristband of a luminox watch
If you have a new wristband, there is a spring loaded lug where the band joins the watch, use a sharp knife or jeweler's screwdriver to slide the lug from the watch
Jun 19, 2009 | Navy Seal Luminox Dive Watch
Crystals framing my Haurex watch face are falling out.
Hi, im a jeweller myself. The problem with jewellers and crystals is simple. Its a lot of work to replace something that doesnt cost a lot to buy (the crystals, not the watch). Swarovski are a commonly known producer of crystals, but you will probably find that simulation gemstones such as Cubic Zirconia are commonly used in newer watches.
I specialise in gemstone setting, and can also work with simulation stones and crystals, but it takes much longer to reset stones into a stainless steel watch case than into gold or platinum so the labour costs are much higher.
It depends how much the watch is worth as to how much you spend on repairs.
Hope this helps
Dec 18, 2008 | Haurex 27473-031-00 Wrist Watch
Timex 5B841 Wristwatch Logo
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
