Question about Nokia HS-26W-BK Wireless Headset
Bluetooth headset is not working
Haii... Im having a nokia bluetooth headset (Model HS - 26W)... Now its not working...... when i press the power button no light is blinking.... i thougth of low battery charge.... but when i put in charger also its not working.... Pls help me..... Can anyone tell me what is the problem....??
SOURCE: Bluetooth headset Nokia BH-600
I too have the same problem. My phone is a Nokia E61i and I upgraded the software a few weeks ago and since then the headset does not work. I can get the phone pair and recognise the headset, but I hear no sound through the headset. I have tried pair the phone and earpiece a number of times, but no luck.
Posted on Feb 19, 2008
SOURCE: BLUETOOTH HEADSET
Obviously a compatibility problem. Bought a new headset!
Thanks for trying
Posted on Aug 18, 2008
faceofftech
  • 185 Answers
SOURCE: I would like connect Nokia bluetooth headset
go to the menu on your phone select manage connections turn on bluetooth then you'll see search listen, etc. position on search don't press yet
get your ear piece ready: press the on button and hold it until you see a solid blue light (not blinking but solid) if it blinks try again until you get a solid blue light (it takes about 5-8 seconds) when that happens go to your phone and press search it will look for devices (it may find several) look for your earpiece model and select it
it will ask for a code or passkey, type 0000. Then it's going to ask if you want to bond or pair click yes and it will connect
check on the connection manager again and your bluetooth should be on and connected.
if it works for you, don't forget to rate me
thx
Posted on Jun 07, 2010
micromatikal
  • 2777 Answers
SOURCE: i have nokia e71 mobile
The passcode is just "0000" without the quotes of course.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Posted on Oct 21, 2010
SOURCE: Bh-105 bluetooth headset not pairing
U must RESET the Headset.
Switch OFF the Headset.
HOLD the answer/end key + power key (for about 5 second).
Red + Green indicators lights start to alternate.
Then Ur Headset is RESET.
Connect / Pair it as normal.
Posted on Jan 08, 2011
I can't pair my new bluetooth headset-genius (HS-905 BT) to my sony ericsson experia x10.
As of 2012: the button to hold is POWER.
1. make sure HS-905BT is off (hold Power till the blue light goes off, you hear descending sequence of tones)
2. hold Power to turn on (ascending tones, blue LED on) + KEEP holding Power till the blue LED flashes twice and you hear a double-beep. Device is ready for pairing.
Jun 02, 2012 | Radio Communications
Nokia bluetooth BH-105 not pair with samsung galaxy y duos GT-S6102
Press The power button for 10s or more of your headset. When both blue and yellow lights flashes then put on bluetooth of your phone and connect it.
It works. I know it cause i have tried in.
Mar 14, 2012 | Nokia Bluetooth Headset BH105
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
Jun 07, 2011 | Nokia Cell Phones
Need password to make my earpeice work, have thrown away box. NOKIA HS-107W
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Jan 03, 2011 | Nokia Bluetooth Headset Headset
I have a nokia 3660
Yes,its a virus job.to solve it only by reprogramming with a latest version.and also cleaning your memory card.or you can tray a fingers formatt first in some case its works.
Mar 18, 2009 | T-Mobile NOKIA 3660 HS-37W Bluetooth...
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Nokia HS-26W-BK Wireless Headset Logo
55 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
