Question about Mitsubishi WT-46809 46" Rear Projection Television
Mitsubishi WT-46809 HD TV Projection
Recently my tv started to switch from vibrant color to a bleached out picture once it changes to bleached out it usually stays that way until you turn it off and back on. I have tried playing with all the settings to no avail. I would like to fix this problem myself if I could does anyone know what would cuase this problem?
  • 1 more comment
  • asenna Sep 28, 2007
    Why pay for internet advice when I can put that towards actually having a repair man come to my house.
  • asenna Oct 03, 2007
    Well given your display of knowledge, I think I made a wise choice. $299.95 for a repair man! Hah, try $85 to come to your house and diagnose the problem. All I would get here is a diagnosis, and then it may not even be correct given you can not physically see or touch my tv besides there are other resources on the internet where I can get opinions for free. So lets see you are charging almost 12% of what it would cost to get a absolute diagnosis and potentially have the problem fixed on the spot, One can never be sure if the internet diagnosis is actually correct. So now lets see your estimate was 3.5 times greater than actual cost for repairman diagnosis, if this is the accuracy I can expect from this service then odds of getting an accurate diagnosis must not be that great. HMMM Math Complete...I choose NO DOUGH FOR U! I would be surprised if this post remains up for all to see.
  • vancere Apr 14, 2009
    I can not seem to adjust my WT-46809 to get red. For example the color of Tiger Wood's shirt on Sunday was red it was black. How do I solve this?
WT-46809 TV GETS REAL BRIGHT TURN IT OFF AND BACK ON AND ITS HAS A NICE PICTURE
Posted on Apr 28, 2008
  • CANDY CANE Apr 28, 2008
    WT-46809 GETS REAL BRIGHT
  • CANDY CANE Apr 29, 2008
    WT-46809 TV GETS REAL BRIGHT . YOU CAN NOT AJUST IT. TURN TV OFF AND BACK ON IT WORKS GOOD FOR 5 MINS
    Genius:
  • 1,153 Answers
Try live support!
Posted on Sep 24, 2007
  • Lashawn Robinson Oct 03, 2007
    Well One reason being only 9.95 here and 299.95 for the actual repairman, you do the MATH!
  • Lashawn Robinson Oct 04, 2007
    Well Sir, seeing you seem upset, I will say with the little Knowledge I have that it is not about the Dough with me. I am happy that you got your set fixed for only $85. But what you would have gotten for the 9.95 we spoke of was this: White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change. See with the little knowledge I have from working on sets like these for over 20 years, I probably could not help you in the first place.
    Have a nice Day!!
I have a 46" rear projection Mitsubishi TV that recently started producing a wavy picture. The reds, blues, and greens separate into wavy color bands distorting the picture. It usually goes away for...
your problem is most probably in convergence circuit.  very common for this model to have convergence output i.c.'s go bad  also possible that a fused resistor or two has failed.
Jul 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Mar 03, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Wt-46809 has convergance issues
Replacing the Convergence IC's should do the trick. But it is not a easy repair do to the disassembly requierments. I would recommend calling Mitsubishi at 18003322119 to get a local service facility to come out and give you a estimate to repair.
Jun 21, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Color Gun Help?
this tv will need some testing to determine the exact cause but most likely it will need a conversion done, you will need to call your local repair shop to come out and fix the problem
sorry about your tv
electech
Oct 26, 2008 | Mitsubishi WT-46809 46" Rear Projection...
HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Apr 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 pitcure is gone
your tech didnt know what he was talking about because that model usually only has problems with bad compacitors which is usually a very inexspensive fix however if he replaced the chip he probably replaced the eprong and failed to reprogram I would recomend you getting a service manual for your tv with online free tech support that wll try to help you straighten out this problem because it would be much cheaper than replacing either the board or your tv you may be able to fix this yourself with the tech support or at worse case senerio the tech will be able to get you a new board for a lot less than 500.00
heres the link
http://servicemanuals.vstore.ca/
Apr 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-42311 hd tv has "pulsating" problem
A Mits qualified tech and/or warranty repair facility near you should be consulted.Involve Mits in the repair loop for accurate info.
Sep 26, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
253 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
