Question about Sony Computers & Internet
Window loose its not tight may it repair or not
    Novelist:
    Scholar:
  • 106 Answers
If it's in warranty send it back to be repaired. I'll assume that you know that. I also assume that by "window" you mean "screen". If I owned it, I would try to see where it is loose and try to wedge a piece of non-conducting substance, preferably rubber, into places that will tighten it. Take a cheap piece of rubber and use a utility knife to shave off the pieces that you need. Don't think that this is a permanent solution - the root cause of the problem still exists and you may be doing this frequently. My second choice, assuming that it's a good laptop would be to take it to a computer repair shop. However, first get an estimate. You may not want to spend that much money on the given laptop, new ones are constantly getting cheaper because the sharply increasing sales of tablets are cutting into the sales of laptops and desktops.
Posted on Nov 14, 2013
Goes into zigzag when straight line sewing
it depends on the name brand of the machine, call some sewing machine repair shops tell them what it doing and ask about repair prices and then decide what to do .
May 25, 2015 | Sewing Machines
Rearview mirror is loose
there is a screw that holds the mirror to the window tightly that needs to be tightened just enough to remove and looseness.
Aug 08, 2014 | 2004 Chevrolet Impala
My ac, windows and neither gas and temp gauge work what can cause this to happen?
sounds like you have a bear wire somewhere that if it rains or snows or wire could be wet,or loose but stays connected enough to stay charged..wiring is fautly somwhere.its not grounding out so you will not blow fuses.check for loose or corrode wires
Mar 19, 2013 | 2003 Chevrolet Malibu
Stitch too tight on top, too loose on bottom
This is a problem with thread tension. The needle thread is too tight and the bobbin thread is too loose. I don't have one of these machines, but there should be either screws or knobs to adjust. Look at your manual. Here's a page I found on bobbin tension.
https://www.manualslib.com/manual/1022927/Toyota-Quilt-50.html?page=50
Aug 06, 2017 | Toyota Sewing Machines
2001 mustang gt converable. Passenger side window will not go up and down from drivers side controls. Will work from passenger side though. I replaced all new switches on driver side thinking that would...
It covers all under repair manual. I have visited this website 2-3 times for the repair of Mustang manuals. They provide all kinds of manuals at a very cheap rates. Check it may be you will get something useful
https://www.reliable-store.com/products/2001-ford-mustang-coupe-workshop-service-repair-manual
Feb 02, 2018 | 2001 Ford Mustang
Driver side window will not come up. motor is working but window will not come up
the window regulator has probably broken or the gear has stripped inside the motor. pull the door trim off and see if the wire from the regulator is still conected and tight, if its loose then its probably broken and will need replacing, if it looks tight then try and pull the motor off the window reg and check the regulator drive gear. hope this helps. cheers.
Jun 03, 2011 | Nissan Maxima Cars & Trucks
The driver's side rear window problems
You will need to replace the window regulator assembly. Both of the cables should be tight. When is loose its because it has broken in the regulator. The cable regulators are a poor design.
Dec 06, 2009 | 2000 Pontiac Grand Prix
The driver's side power window is skipping or
Most likely the rail has come loose inside the track you can drill a hole and put a #20 nut and screw in it to hold it tight so it won't move the track is the most common thing to wear out on the window. once you repair it it should be fine check all four corners the most common break is in the lower right side looking at the door with it open. Also the track will come loose as well and that can cause you the same problem, with the cover off the door operate it so you can determine which area it is jumping from and then fix it. also lube the tracks with synthetic grease to keep it from being hard to roll up also lube the rollers in the bottom of the track.
Jul 17, 2009 | 1999 Chevrolet Blazer
Window off track on my expedition putting back on the holders sho
this black holders are part of glass and glass should be replaced
Mar 09, 2009 | 2000 Ford Expedition
Phone Locked
if in ur phone have side keys for volume or for camera. then first check ur side keys. keys should be loose not tight if anyone is tight ur other keys will not work if keys are tight then make it loose , if are loose then need to repair it.
Feb 17, 2008 | Samsung SGH-x427m
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
