Question about HP Pavilion DV6500Z Notebook
Screen black out
I turned off my laptop. when i tried to turn it on again nothing appears on the screen, but there's a sound that it actually turned-on. i might have pressed a key or done something. what should i do to fix this. I have a problem with my laptop, it turns to blackout. then i try to turn it off, then after turning if off i try to turn on my laptop, but the screen was the same. It's blackout. theirs nothing that can display it's fully blackout. So what should i do with that?
  • Michael Slabbert
    Michael Slabbert May 11, 2010
    try taking out the battery for about 10 min. then plug in the external power without the battery and see if it turns on then.
  • 46 Answers
Best way to trouble shoot a monitor is to plug into a different monitor do you have a desktop monitor you can try?also alot of laptops have a small button that turns monitor off when you shut it down around the base of the monitor make sure it isnt stuck.is it going into hibernation? try pulling the battery and unplugging it then plugging it back in.if it is stuck in hibernation that should work.
Posted on Apr 23, 2009
Black screen
Hi Julius,
remove the battery and replace again and plug the adapter and turn on laptop.
if you cant see anything .please look carefully your lcd panel and see it is starting up and bios messages.
if yes.
your back light cct is gone....
i think no problem with flash player and it was hardware failure..
regards,
nuwan.
Jan 20, 2014 | Dell Vostro 1710 Laptop
Can't turn on Dell Inspiron 1501
dear sir , acutully your dell laptop is in hibernation mode, and is not coming back
you can try following:
1. remove batter plug directly and try to switch it on without battry.
or
2.press power switch for 13 sec continusly and once it shuts down , switch on it again
this will definatly help you
thanks
Dec 11, 2007 | Computers & Internet
Picture went black during viewing and won't return
its looks ur screen is DEATH.........as u only have the set for 18 months i assume u have no warrentie left'
may go in touch with TOSHIBA and tell them ur problem u have......
but it looks to me u need a new screen,,,,,or may a service will solve ur problem,,,,,it may cost u .......but may cheaper as a new screen
Nov 20, 2009 | Televison & Video
My Travelmate 290 series is not working...
Try taking the memory out and then put it back in making sure it seated correctly then start using AC power lead it's probably caused by letting the battery get too low before recharging.Use a start up disc to get it going if you have to. Good luck
Aug 02, 2009 | Acer TravelMate 290 Notebook
There is no display and not able to reach BIOS
Phenomenal!
Did you not think that knowing what make, model of laptop could help?
It sounds like it is broken!
Jun 29, 2009 | HP Computers & Internet
Acer aspire blue screen appeared went off now laptop starts up for few seconds then turns off again, but always a black screen hear the fan a few seconds but nothing
Try this:
  • check to make sure the fan is actually spinning and that there is no debri (dust bunnies) causing it to overheat.
  • Make sure there is nothing preventing airflow, you may need to tilt the back up to allow more airflow
Is there any display at all? Do you see a BIOS splash screen? Do you hear a beep shortly after powering on?
--if you have a splash screen, go into BIOS setup by pressing a button (del,F1,F10...whatever) then set it factory defaults and save changes
--also try removing anything that's detachable (USB, cards, dvd-rom, RAM, Battery...) Hold down the power button for 20 secs then plug in only the A/C and see if you get a bios screen
Hope this helps
Jun 10, 2009 | Acer Aspire 5100 Notebook
Wont turn on
Hello, It looks like a dead hard drive... To check your hard drive and see if you can repair it yourself, reboot your computer press simultaneously the "cmd" and "s" keys at startup if you see a black screen with white text, type: fsck -f and hit enter this does a "file system check", when finnished, type "reboot" and press enter. If nothing better happens, you'll certainly have to brinng it to an Apple Authorized Center Best regards
Jun 10, 2009 | Apple MacBook Air
Laptop won't start up
It sounds like your laptop is using it's external VGA adapter for its main display. Try holding down the Function (FN) on your keyboard located on the bottom left hand side and pressing F4 at the same time.
Jun 04, 2009 | Compaq Presario Notebook
Nothing appears on my monitor
Might be dead... try to leave it off for w while before trying again. check all connectors and if it still faisl to work your going to have to get a new one. Before that check your warranty and dealer and se if anything is coverd. best of luck
May 25, 2009 | Toshiba Satellite Pro 6100 Notebook
Screen black out
Remove the battery and use only power cable and turn the laptop on to see if there is any problem with the battery.
Thanks and Regards,
Mar 29, 2009 | Computers & Internet
HP Pavilion DV6500Z Notebook Logo
304 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
