Question about HP Deskjet D2360 InkJet Printer
Belt for cradle movement slipped,dont know how to re conect the belt...plz help me with this :(
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • HP Expert
  • 177 Answers
You will have to dismantle the entire machine to remove the axle that holds the cradle in place , and remove the cradle and then you would be able to fit the belt back
Posted on Oct 11, 2013
Squeeky noise coming from engine
Sounds like the belt is too loose. It slips and the alternator stops turning and the light comes on. Look online on "how to" adjust the belt.
Good Luck....should be a simple fix.
Mar 02, 2014 | 1996 Geo Prizm
Fan belt is squeling
First thing to check is see if the belt is slipping.. .If so is belt loose ?
test by pushing down. Excess movement = loose solution = tighten.
Does it slip on engine tickover ..or when engine is revved?
Jan 25, 2013 | 2000 Honda Civic
My kitchenaid washer has a burning smell
Hi, a slipping or severed belt will produce a burned rubber smell. A belt supports the drum and ensures its smooth movement. If it wears, the drum's movements weaken and finally come to an abrupt halt. In addition, a slipped or severed belt usually produces a burned rubber smell. Refer to the washing machine manual to review how to locate the belt. If the belt is no longer around the drum's center, shift the belt back to its original position. If rubber fibers are discernible or cracks are apparent, change out the worn belt for a new one.
Thank you.
Jun 05, 2012 | Washing Machines
Tunturi J5F - Motor v-belt tension
Just tighter than slipping. Over tightening can brake the shaft since it's not usually a steel shaft.
Jun 07, 2010 | Exercise & Fitness
How to change fanbelt on 1996 bmw 318 ic
loosen off the alternator about 1 inch, then slip off the belt, replace belt, then re-adjust alternator till its bolts are finger tight, check the movement in belt by pushing down on belt with finger till it moves only 1 inch of movement, on the longest part of the belt )......then tighten the alternator bolts
Sep 06, 2009 | 1996 BMW 318
Ariens 20/48 zero turn left wheel dont want to go.
sealed units factory, take the wheel off see if the key has broke looks like a flywheel key but longer may have sheared stopping the movement of that wheel
Jun 29, 2009 | Ariens 34 In. Zoom Series Riding Mower
I had to order a belt for my turntable that was disinagrated so I dont know how to put the new one on. could you please either show me a picture of how it goes on or explain
First, remove the rubber mat (platter cover)
Next, there should be 2 oval shaped slots in the aluminum platter.
Carefully rotate platter until you can see the drive motor pulley through one of these slots. Lift straight upwards on platter to remove it. On the underneath side of the platter, there is a surface that is approximately half the diameter of the platter. Place the new belt around this surface, ensuring that it is not twisted.
Fun part.....Turn the platter right side up and insert index finger through on of the oval slots. Slip belt over finger between belt and platter "pulley" surface. Carefully reinstall platter with finger/belt slot lining up with drive motor pulley. Slip belt over drive motor pulley and remove finger, making sure the belt is not twisted. Now, manually rotate the platter to check for proper belt movement.....if all is well, reinstall rubber mat (platter cover) This concludes belt installation.
Jun 11, 2009 | Technics Audio Players & Recorders
How do you conect your sound rocker to your tv
if you have a game system that you try to use the sound rocker for sound you either have to by a cord connector or if you have the Xbox360 with the hdtv cord you can connect the cords to the sound rocker and the tv
Apr 12, 2009 | Pyramat Sound Rocker Gaming Chair
Meadelx200 declination movement
I'm going to assume that you know you need to tighten the DEC clutch knob, and that this was already done.
There is an internal belt that connects the drive motor to the worm gear that engages the DEC assembly. Sounds like the belt has either broken or slipped off the pulleys.
The belt is model and size specific, so you'll need to contact Meade for a replacement.
You should eyeball it to make sure that's what it is before ordering anything.
Sep 06, 2008 | Optics
HP Deskjet D2360 InkJet Printer Logo
80 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
