Question about Garden
Vw 2e 2l engine block lenth from sump flange to top off block
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Good question
Posted on Dec 30, 2013
How do i remove the sump of a 2e
FWD right
have to lift the motor and support it
front exhaust back to the cat has to come off
center brace removed
should be able to reach the sump bolts from there
note
the 2e motor doesnt take a gasket,just sealer, the toyota sealer is the best,
Feb 17, 2017 | Cars & Trucks
What can possible be the cause? I have a Renault Master II diesel 2003. New engine block, new top, new oil pump.But, engine loose oil pressure when warm, about 0,5 bar measured.
possible air leak from a badly installed gasket at the top of the pump pickup tube in the sump
it has been known that a rag has been left in the sump during overhaul and can be blocking pickup
(rag is left on the crank shaft or big ends when the block is inverted during assembly and the sump is put on over it )
Jun 19, 2016 | Renault Cars & Trucks
1998 ford mustang 3.8l v6 leaking cookant from bottom of engine. Not sure where. Looks like it could be from the pan right under the engine
most probably from a rusted welsh plug in the block. Have the coolant system pressure tested and watch for the leak as it is probably running down from the welsh plug and collection at the sump flange.
Jun 10, 2014 | Cars & Trucks
Over the winter my water flange on my 2000 VW beetle, cracked. We noticed once the car over started flashing the high coolant temp alarm. I replaced the flange and re filled the engine coolant, now it...
First check your oil to make sure it is still clean. You also need to have your coolant system pressure tested. Sounds like you have a cracked block.
May 25, 2011 | Volkswagen Beetle Cars & Trucks
Were do i find my engine code ford mondeo 2005
Ford Mondeo Zetec 3 Digit code maybe found on the cylinder block adjacent to oil pan rail (oil sump flange) on the exhaust side, or on rear flange of cylinder block adjacent to crankshaft position sensor.
Ford Mondeo V6 Duratec 3 Digit engine code maybe found on lug at rear of cylinder block adjacent to oil filter and front cover of engine.
Sep 13, 2010 | Piston Keychain
Crankshaft sensor for vw polo where is the
Crankshaft sensor is located on the right side of the cylinder block behind or under the starter. It is fitted into the rear crankshaft oil seal hausing
Sep 12, 2010 | 2002 Volkswagen Passat
How much engine Oil?
The engine oil capacity of a Daihatsu Sirion, 1000 cc Auto, 1999 is roughly 2.5L assuming the sump was drained and new oil filter installed.
This amount will bring the oil level on the dipstick to the upper line.
As a caution, put in 2L initially, then run the engine for a few moments then switch off. After a few minutes recheck cleaned dipstick level and top up as necessary.
Mar 16, 2010 | Daihatsu Charade Cars & Trucks
1999 2.0L VW Jetta coolant leak behind crankshaft pulley
The MK3 VW's are prone to failure of the "coolant flange", which is located to the right of the valve cover, and will have 4-5 hoses and or sensors sprouting from it.
I'd be willing to bet that this is the source of your leak, not the cam pulley.
The part is inexpensive.
Jan 18, 2010 | 1999 Volkswagen Jetta
Vw transporter 2l 99 model. starting
need to check the main wires try putting a jump lead on the pos battery and then to strter to to see if it turns over if does then some thing wrong with wiring
Nov 01, 2009 | 1986 Volkswagen Wagon Camper
Coolant leaking on a4 2002 1.8t
If the coolant is droping on top of the trans, then it is the coolant flange located at the back of the engine then it is the coolant flange,like the person above mentioned. I had happen to my A4. The part is like $20 i believe if you get it yourself, plus new coolant, VW kind. Get the flange and a new o-ring do not try to re-use. There is a DIY for it if you google it : http://www.audizine.com/forum/showthread.php?t=84054. I chose to take it to a shop it was 2-3 hours labor. Just make sure they know what they are doing. The spot is a pain in the ***, and if you have big hands don't even think about it. Well worth the pay to a shop!
May 14, 2009 | 2002 Audi A4
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
