Question about Electrolux Washing Machines
Electrolux washing machine 14kg Error code 19 master comm
  • 49 Answers
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
SOURCE: Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Posted on Nov 20, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
e-Guru
  • 3917 Answers
SOURCE: error code e40 on my washing machine electrolux
The Error E40 warning means the door is not properly closed. The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Thank you for contacting Fixya.com
Posted on Aug 06, 2009
SOURCE: Electrolux ewf1087 washing machine error code?
what is a (e40)
Posted on Jan 02, 2010
Please, how can I solve the fault code 19, Master COMM. On my Electrolux W4240H washing machine. All the engineer u contacted didn't get it. Please, help.
Error code 19, MASTER COMM.
Communication with superior system has been broken. The cause can be an error in the network connections, damaged cable, defective monitoring system, etc.
Action: • Contact the supplier of the monitoring system for possible causes of the monitoring system not communicating.
Dado
Aug 20, 2015 | Electrolux Washing Machines
Electrolux Error Code E=19
Good Afternoon Friend,
I understand that you are receiving an E=19 error code on your Electrolux washer, model# EW1200i. I have researched your appliance and noticed that it was manufactured in the UK. What is suggested for the North American appliances is to reset them, by either unplugging them or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this. If this does not work, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Electrolux EW1200i Front Load Washer /...
4250N
Action:
Dado
Jan 07, 2014 | Electrolux Washing Machines
When we start auto on the display appears error 019 master comm
same problem with our machine also, error 019, Anyone can help us to assist fix this problem. thanks
Dec 27, 2013 | Electrolux W4180N
My Electrolux washing machine W4180N has faul error 6 (e6), how to fix the problem
I'm not finding anything in my literature on that code. I would contact electrolux directly.
May 30, 2012 | Electrolux W4180N
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
Error on screen if load bigger - DE
Hello,De error refers to "Door Error".
You do not need to buy a new machine. You can fix this.
Look at the below mentioned link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
Thanks
May 24, 2010 | Samsung SW62ASP Top Load Washer
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
