Question about Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Gas oven operation
As im new in rangemaster family im not sure if the operation of my gas oven is proper. Gas oven is sparking continiously during its operation, is this normal?
  • Anonymous Dec 19, 2008
    I have a simiar problem when i turn the gas oven off - the hob igniter clicks - i think it is a dodgy knob as it seems to be tempermental - any suggestions. It's a newly installed oven !
  • 640 Answers
Spark should stop when burner is lit.clean the probe with a light sandpaper and see if this corrects it.
Posted on Sep 29, 2007
SOURCE:
My rangemaster professional + 90 gas is when you turn on the oven and turn up the gas all the burners igniters start working can you please help .
Hello. Normally the ignitors WILL all start sparking--only the burner you've initiated will turn on. All the ignitors are wired together with a harness underneath the cooktop. This harness is connected to a spark module and when you choose whichever burner, it simply energizes the module. Only the burner with gas flowing will ignite. I hope this helps you!
Sep 03, 2015 | Rangemaster Kitchen Ranges
We bought a brand new dual fuel Rangemaster cooker and the adaptation of our bungalow and building works have now been completed and ready for the cooker to be installed. However, my husband ( who has a...
I used to have the same range with 2 electric ovens, but it is available with the lower large oven on gas and the tall oven electric.
The manual for theToledo with tall electric and large gas oven can be found here:
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/Toledo90Gas.pdf
The manual for theToledo with both electric ovens can be found here:
http://www.rangemaster.co.uk/media/575792/toledo%2090%20dual%20fuel.pdf
The main product page for the toledo 90 can be found here:
http://www.rangemaster.co.uk/range-cooking/toledo-90.aspx
Sep 16, 2011 | Rangemaster Toledo 90 (Dual Fuel) Dual...
I have a rangemaster 110 and yesterday a gas engineer came out to my boiler . He may have switched the gas off, im not sure. However, today neither of my ovens will come on and my clock has gone out too??...
make sure you dont have a circuit breaker triped in your electric pannel if the power went out it seems to be the culprit and does the range come on at all because the ingnition on it should be an electric ingnition as well hope this helps
Jun 11, 2011 | Rangemaster 110 (Gas) Kitchen Range
Ovens won,t function, no spark or gas but gas hobs work fine
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 30, 2010 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 LPG Range (5364) right hand oven lights but flame only stays low? What is the likely problem please
Is this new and recently converted to LP-Gas? Did you install it and convert it or did you have a professional do it? It sounds to me like the wrong size orifice for the oven may have been put in. Was the appliance regulator converted? When you flip the cap, it allows more pressure to the burners, but this affects all stovetop & oven burners, not just one burner. Some ovens require converting the oven thermostat too, but not sure if it applies to this brand. Check your owner's manual and make sure all the steps in the conversion were done. If you had a pro install and convert it, call them back to fix it. Douglas
Jun 12, 2010 | Rangemaster 110 (Gas) Kitchen Range
Oven is igniting but not getting hot
got the same problem on a rangemaster 110 - just had the comet engineer look at it - changed the thermostat and the spark generator - no effect. poss the flame failure device or the timer.
Nov 15, 2009 | Rangemaster 110 (Gas) Kitchen Range
Gas oven
Its the flame failure device faulty (FFD)
Nov 30, 2008 | Rangemaster 110 (Gas) Kitchen Range
Left hand oven not getting hot!!
some older ovens did use one side just as a "bread warmer"...only way to tell for sure is to check if there is a burner below the left side
Jun 02, 2007 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
436 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
