I want to connect to LCD projector but I can't what is I missing
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 60 Answers
What is the make and model of both the computer and projector?
If you can provide this information, we should be able to help you with your problem!
Posted on Oct 21, 2013
Does the Sanyo multimedia prox-III hook to direct tv
Sanyo connect directv Multimedia Projectors Questions ...
www.fixya.com > Forum > Tags > connect directv > Multimedia Projectors
Sanyo multimedia projectors connect directv related questions and answers. ... 3Answers ... configuration hey...i have a sanyo PLC-SU30 PRO-X MULTIVERSEPROJECTOR and i can't connect it to my laptop,i have connected the cable and ...
Sanyo Pro-X multiverse projector - YouTube
? 1:46
https://www.youtube.com/watch?v=awwXqdPRkNw
Feb 27, 2013 - Uploaded by WeeePC
Sanyo Pro-X multiverse projector start up. ... It was Sanyo at first sight!! ... 3:49. How we setup our LCD projector to reflect onto the kitchen table ...Missing: directv
db:: 5.32::MBP and Sanyo Z2 Projector 19
www.hivmr.com/db/199a98kjjjjz33k9kzk9p8kdfc1cdfjs
i have a hp g60 laptop and want to connect it to a sanyo pro-x projector, but i cant find it on the ... problem: I have a Macbook Pro 2009 running 10.6.3 and an Epson Projector.... You should hook up your projector to the DVI or the VGA. ..... I just bought a Sanyo Multimedia Projector (PLC-XU25A) and I can't get the projector ...
Jan 20, 2016 | Sanyo Office Equipment & Supplies
I have my G60 laptop connect to an LCD projector. I wanted to turn off the screen on the laptop and hit Function F4 which i have done in the past and it took the picture off of the LCD projector and now...
Disconnect the cable that is connecting the laptop to the projector. Sometimes this will happen if the projector or device you're connecting your laptop to does not support the current resolution that the laptop is displaying. Reconnect the cable and try using Function F4. If that does not work then disconnect the cable from laptop to projector, reboot the laptop then repeat connecting it to the projector and pressing Function F4.
Feb 23, 2011 | HP G60-120US Laptop
Epson 76c, replaced lamp, doesn't come on, then replacment light comes on and high temp comes on, is there a reset i'm missing?
you did a goog job, there is nothing missed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Sep 09, 2010 | Epson (V13H010L34) Projector Lamp for...
Projects only a purplish screen. Bulb is fine.
You are missing a primary color you could have a bad cable or connector pin bent/missing. It could even be at the port on the projector. May want to try a different cable to verify.
Jun 16, 2010 | Epson EMP-S4 LCD Projector
There seems to be an HTPS LCD panel missing. I
Awfully expensive. It Usually writes the machine off for the sharp Projectors. Don't Bother. Uneconomical + Hours spent alligning it.
Nov 13, 2009 | Sharp PG-A20X Multimedia Projector
Connect projector to HP desktop
If you are attempting to connect an LCD projector to a laptop,you connect a monitor cable to your video card and the other end to the monitor input connector. You may have to use an adapter, I know on my LCD projector I had to use a DVI to VGA connector.
Can't say much more not knowing if you are having a problem with a particular brand of projector
Sep 21, 2009 | HP Pavilion a705w PC Desktop
MISSING CABLE
you can buy any vga cable at any electronics shop in your area. usually epsons pin configuration is just standard so any vga cable will do. also try to look for it in any computer surplus store (if theres any). LCD TV nowadays has a bundled vga cable that will work with your projector too.
Jan 31, 2009 | Epson (ELPLP25H) Projector Lamp for...
I have a HP lcd projector. It works fine when connected to dvd player but when connected to PC it does not. The picture and other icons are ghosted! is the problem with pc or projector?
PC either driver missing or wrong one.
GO to the HP website with you model number and the version of windows that you are running and download and install the driver for your icd projector device for your computer . It must match the version of windows that you have. If one is not availavle then you cvannot use the device with the computer untill one is written.
http://welcome.hp.com/country/us/en/support.html
Jan 15, 2009 | HP Compaq d530 PC Desktop
Bad connection between laptop and lcd projector
First, check all plugs and make sure there are no broken or bent pins in them. If the projector you are using have a replacable cable try to replace it to see if the cable is the problem. (borrow a cable from a friend or relative first so you don't buy one if it is not needed.)
If that doesn't fix it, try to connect a different computer to your projector to see if that is better. If so, the output port on your computer may be bad.
Also try to hook your compuber to a different monitor to see if that works. If no computers are able to make a good picture on your monitor, the monitor is at fault.
The fact that you can change the picture quality by wiggling the cable, and that it starts to search for a signal suggests that the cable or the plugs are at fault, but having the wrong resolution set up on your computer may also affect the image quality. Again, try to use a different computer as a source to eliminate (or confirm) your computer being the problem.
Feb 19, 2008 | Compaq Presario 2140US Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
