Question about Panasonic Televison & Video
I have a Panasonic tx-p42g20e that sometimes works for a minute or two. When not working the red light blinks 13 times. Any ideas?
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
Yazz226
  • 497 Answers
SOURCE: screen flashes and power light blinks 8 times
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
Thanks for using Fixya
Posted on May 05, 2009
  • 556 Answers
SOURCE: my panasonic (pt50lc13) keeps shutting off after a few minutes.
probably lamp gone out. You can change it youself if you still have owners manual should have directions, if not most lamps have instructions in box.
Posted on Aug 11, 2009
asnowman
  • 788 Answers
SOURCE: my panasonic rear projection t.v. will not turn
Your symptom sounds like a damaged convergence IC.
If this is the case the power LED should be blinking 3 times when trying to power the set up.
You should be able to get a local service center to repair this at
your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and
heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old
heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center
circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews
Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their
phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the
phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a
good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this
information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Jun 24, 2010
My Panasonic veira tx-50b6b will not stay on. When I switch it on it tried to come on the screen flickers then goes off. I then get a red flashing light the remote doesn't seem to work either.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 24, 2015 | Panasonic Televison & Video
My TV Panasonic TX-P50GT30 do not work any more. I have the light blinking 7 time in red.
7 blinks means that you're to replace power board (it failed on start test).
May 10, 2015 | Panasonic Televison & Video
Why does my 4year old Panasonic plasma flat screen tv have vertical stripes and will often not turn on but red power light blinks?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
LED blinking codes to Plasma TVs too is given.
Mar 23, 2015 | Panasonic Televison & Video
TV stopped working, how can I fix the problem below?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 12, 2014 | Panasonic VIERA TX-L32X5B 32" LED TV...
TX-32LZD81 fault red led flashes 13 times, repeating regularly after being taken out of standby. The led goes green initially for several minutes before it starts flashing
13 flashes denotes a fault to its main board. If you wish to get more details about these blinking codes, check this link.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 18, 2013 | Panasonic Televison & Video
Panasonic TX-32LZD81 screen stays dark when brought out of standby. Red led changes to green but then after apparently doing nothing for a long time, it turns red again and flashes 13 times repetitively
These flashes are fault indications, and are called blinking codes. From the number of these blinks, you can get an idea about the faulty circuit stage inside the TV. Count it carefully, and make sure about the number of blinks occur at one time switch ON. If you wish to get more details about these blinking codes, check the site linked here.http://electronicshelponline.blogspot.com/
Sep 18, 2013 | Televison & Video
Red light blinks 8 times panasonic plasma tx-p42G20E
8 blinks, is a code related to a bad performance of the main power supply, undo the back and check for bulged or swollen capacitors.
hope 2 help
www.bostonrecycling.net
If you need it... we have IT !
LCD PARTS / PLASMA PARTS / LAPTOPS PARTS
Jun 25, 2012 | Panasonic Televison & Video
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
My panasonic is not coming on,the power button is just flashing red(TH-42px50u)
Count how many times it blinks. Sometimes the problem is coded in the amount of times it blinks. If you see a distiction between blinks, say like 13 then a pause then back to 13 more blinks, google solutions for a 13 blink standby for your tv and you might be able to find the soultion.
Jun 14, 2010 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Televison & Video Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
