Question about Stihl Concrete Cutoff Saw Carburetor Ts350 Ts 350
My TS350 Super is leaking fuel on the bottom. It runs fine. However continually leak fuel. If I stop it, fuel continually leak out of the bottom. Any suggestion? I have no idea of the internal components, & setup. Where can I find a service manual for this Saw?
2 Suggested Answers
  • 2239 Answers
SOURCE: My Brand new Stihl ts420 cut saw wont run full throtle, smokes white, and leaks fuel out of exhaust filter. it runs like the choke is half on.
This sounds like the carb is flooding, there is a rubber tipped needle under the metering side of the carb, this may be leaking, before replacing the needle make sure the air filter is not blocked, replace with a new filter and try again
Posted on Feb 18, 2012
My 1990 ford f150 is leaking gas out of one of the fuel injectors when I picked it up from getting a transmission put in what could be the problem?
Probably a failed injector O-ring that seals against leaking. Maybe it got jarred while replacing the transmission. Should be two O-rings per injector, one at top and one on bottom.
Jan 09, 2016 | Ford Cars & Trucks
2006 Dodge Ram 2500 Cummins 5.9 leaking fuel. Engine still runs just fine, but fuel leaking heavily from under the cab(not close to the fuel tank).
There are several fuel connection points in the fuel lines which run from the tank to the fuel pump through the left frame rail. Check these connections and look for any damage to the fuel lines. Additionally, the fuel filter on the left rear of the engine has a water bleed off knob on the bottom. This knob could also leak by the left front corner of the cab.
Sep 24, 2013 | 2006 Dodge Ram 2500
Fuel drains out of tank when i start the engine
More that likely when you fell the lines to the carb got damaged or partially disconnected and are leaking or the carbs(if it has carbs) has a stuck float which would allow fuel to over fill the bowl and pour out. The petcock is a vacuum controlled unit so that's why it does not put out any fuel until the engine is started (which is when it leaks). The tank may need to be lifted up some to see where the leak is coming from. If the lines are ruptured then replace them. If the carbs are leaking, tap on the bottom of the bowls with the back side of a wooden hammer (or something soft) and sometimes that will make them stop leaking.
Jan 17, 2013 | Motorcycles
Need repair manual for stihl ts350 super
Download Link:
This service manual contains detailed descriptions of all the repair and servicing procedures specific to this power tool series.
1.stihl ts350 parts manual
There are separate handbooks for servicing procedures for standardized parts and assemblies that are installed in several STIHL power tool models. Reference is made to these handbooks in the appropriate chapters in this manual. As the design concept of models FS 120 FS 200 FS 300 FS 350 FS 400 FS 450 and FR 350, FR 450 is almost identical, the descriptions and servicing procedures in this manual generally apply to all models.
2.stihl ts350 parts service manual
Jul 05, 2012 | Saws
I have a stihl ts350 cut off saw and if i put fuel into the carb choke flap opening it will start and run for a few seconds then dies like it ran out of fuel i have took the carburater apart and cleaned it...
Hi and welcome to FixYa. I am Kelly
You are going to have to rebuild your carb and get a
GASKET & DIAPHRAGM KIT
  • TILLOTSON DG-2HL/DG-5HL
  • Fits all HL model carburetors
One of your many diaphragms or gaskets is leaking even though it is clean all it takes is a pin hole to cause havoc!
This link provided as a picture reference only:
http://www.gardenhirespares.co.uk/product/173
http://www.gardenhirespares.co.uk/images/1100_orig_listing.jpg
US source for the same kit:
http://ssl.jackssmallengines.com/jacks-checkout/shopping-cart.aspx?CFID=179837&CFTOKEN=92541317
Make sure to download this 8 page manual to help you with the carb repairs:
http://www.tillotson.ie/docs/techinfo_HL_US.pdf
Just make sure you have good fuel flow to the carb fuel inlet from the gas tank with a good rate of flow.
When you finish it will work great if you did it properly. You will for sure have to adjust the fuel mixture screws after the re-build.
Thanks for choosing FixYa,
Kelly
Mar 30, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Espressione CA4865 Supremma Super Automatic machine will not transfer water into the system, but rather leaks out the bottom! What can be done to fix this?
I have same unit. Produced by Solac in Spain. No longer sold in U.S. Solac won't help.
I had leak out bottom of machine. Removed brew group and tightened phillips head towards front which was loose. This stopped the leak on mine. Hope it works for you.
Mar 27, 2011 | Espressione CA4865 Supremma Super...
I replaced the motor on my super 2 pump with a new shaft seal. Put it all back together including electrical and now it's leaking from the bottom. I retightened the screws to make sure they weren't loose...
Most likely leaking from either the shaft seal, or the valute seal (big seal plate o-ring). When you replaced the motor you should have also replaced the shaft seal. If not go back and do that whether it's leaking or not. If you get your head down and look at the bottom of the pump while it's running you should be able to see the water coming from the joint between the seal plate, and the seal plate housing, or just behind that from the bottom of the motor probably from the vent holes in the motor housing. If it's coming from the motor then the shaft seal is leaking, and the water is traveling along the shaft and out the bottom of the motor. This will eventually get into the motor and seize up the bearings. If it's coming from the valute seal, then you need to either replace or re-seat the seal. As a general rule you should always replace the shaft seal, and diffuser and seal plate o-rings when you replace the motor or split the seal. I'm not as familiar with the 2 speed hayward super 2, but the standard super 2's have a small ribbon seal, often called a rubber band. They are infamous for going bad especially after pulling the pump apart.
Sep 18, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Fuel leaking from filter canister area on a 2000 f350
I believe this is a diesel right? If so there is a water drain valve on the bottom of the canister that the lever can leak. Check the oring on the cap to check and see if it is leaking down the side, also check the fuel lines coming out for a leaking or blown oring.
Jan 12, 2010 | 2000 Ford F350 Super Duty Super Cab
Yard machine 139cc will only run short time with choke
Check the float and the adjustment screw on the bottom of the carb. Usually if the float stays up it will continue to leak gas and also will only run on choke. Spray some carb cleaner in there and try to get rid of any debri also try changing your air filter or cleaning it
Feb 08, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Stihl Concrete Cutoff Saw Carburetor Ts350 Ts 350 Logo
82 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
rlev_7
Level 1 Expert
Spud Howell
Are you a Stihl Saw Expert? Answer questions, earn points and help others
