Question about Apple MacBook Air
Macbook Air keeps beeping three short beeps in a loop
The MacBook Air is very hot, when I turn it on the screen doesn't work and it repeats three very loud short beeps even when I close it and try to turn it off.
  • 26 Answers
I need more info on which model Macbook air you have. You can try to reset the smc and pram https://discussions.apple.com/docs/DOC-3604
but three beeps is often memory related
http://support.apple.com/kb/HT5860?viewlocale=en_US .
Depends on the model you have whether or not the RAM is removable.
Posted on Oct 11, 2013
news775
  • 699 Answers
SOURCE: My Macbook Air made "beep
The bios on the machine hardware has failed to book.
You could try plugging in machine and ensure battery is charged.
Press and hold the power button for about 20 seconds.
also the other thing is to immediately after you press the power button.
hold these 4 keys at same time continuously - cmd, alt, P, R
hopefully machine will power up and down and up again if you keep holding them.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 17, 2011
thehumble1
  • 137 Answers
SOURCE: beeping before booting
probably the RAM. Take it out and put it back in to check. You will need some RAM to boot, so try each stick separately if you can. I'm guessing though that you'll have to get at least one other stick of RAM to check. You'll probably find that one is bad. It's probably covered for life, but that would be a good reason to upgrade it.
Posted on Nov 19, 2008
  • 63 Answers
SOURCE: my Macbook Air did not turn on. It made noise like
please connect the adaptor with power outlets
Posted on Jul 13, 2009
  • 26 Answers
SOURCE: My macbook won't turn on. Instead the screen stays
Tones before the Happy Mac or Apple logo means that during the start up process (when Mac checks Hardware) it found something wrong. I have seen this with bad memory, and crashed Hard Drives.
Insert the original CD that come with the machine and hold down the C key and then hit the power button.
Then try to reinstall operating system.
All your data will be there. You may need to enter program serial numbers again but Music. Docs etc should still be there.
Strong believer in TimeMachine. this free software from Apple has saved my life several times.
Posted on Aug 18, 2010
xBEEx
  • 109 Answers
SOURCE: MacBook Air 11" won't power
1. Verify AC power presence with MagSafe LED indicating on or charge state.
2. Verify battery as being partly charged, with orange/amber LED on MagSafe power connector.
3. Reset SMC
Resetting the System Management Controller (SMC) The System Management Controller (SMC) is a chip on the logic board that controls all power functions. If the computer is experiencing any power issue, such as not starting up, not displaying video, sleep issues, or fan noise issues, resetting SMC may resolve it. To reset SMC: 1. If computer is on, turn it off by choosing Shut Down from the Apple menu. 2. Connect power adapter to computer and to a working power source. 3. On built-in keyboard, press (left-side) Shift-Control-Option along with power button just once. Important: Use Shift-Control-Option keys on left side of keyboard. Note: When the LED on the MagSafe connector is orange/amber, resetting the SMC will change it to green for a few seconds, indicating that SMC was correctly reset. 4. Wait 5 seconds and press power button to start computer. Note: If bottom case is removed, you can alternately reset SMC by disconnecting both power adapter and main battery, and holding down power button for 5 seconds.
Power Adapter Issues 1. Connect AC adapter's MagSafe connector to the computer. The LED on the connector should be green or orange/amber. 2. Verify power cord or duckhead is firmly attached to AC adapter. Check that duckhead is not damaged. 3. Verify AC power source is supplying AC power. 4. Check for dirty or stuck pins on the MagSafe connectors, both on the adapter and the computer. 5. Reset SMC by pressing the (left) Shift-ControlOption(Alt) keys along with the power button once.
Posted on Mar 01, 2011
3 beeps mean
The ram is either the wrong kind, bad, or not pushed in properly.
Dec 22, 2013 | Apple MacBook Pro Laptop Computer with...
Macbook pro 13 three short beeps black screen
something wrong with the RAM I think, either not mounted well-check -or the wrong kind of RAM -or a bad RAM socket:
3 beeps on start up macbook-pro-13-three-short-beeps-black-abadwnk1mj4brvvpzp1wcyyy-4-0.jpg
Feb 20, 2013 | Apple Computers & Internet
Macbook 13" beep alarm at start up
Three beeps on a MacBook indicates a problem with the RAM.
Feb 10, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook beeping 3 times and won't turn on
3 Beeping Repeatedly/Continuesly that meaning if :
Failure in a base memory 64K
Base memory 64K is 64 KB first Memory at RAM.
This failure can be because the Slot Dirty,or Pin at RAM dirty,or can be the one of Chip at the RAM is damage.
The Solution is :
1.Remove RAM and Cleanup Pin at RAM,
2.Cleanup Slot RAM at MotherBoard.
3.change RAM.
if this helpfull for you,please don't forget to rate it.Thanks...
Jan 09, 2012 | Apple Computers & Internet
My Macbook Air made "beep beep beep" sounds when I
3 x beeps means there is a problem with the memory, either it needs reseating, replacing or a problem with the slots on the logic board.
Kev.
Feb 17, 2011 | Apple MacBook Air
Many thanks
My MacBook won't turn on!!!
If it is repeatedly beeping it sounds like a memory issue. you should try removing your memory one stick at a time and attempting to reboot.(remove one try to start, replace, remove other try to start). If it doesn't work with either stick try using a "known to be good" or new stick of memory and see if it starts. Here is a link explaining how to remove and change/upgrade your memory. Very simple really, involves removing the battery and removing a plate with three screws in it.
Feb 13, 2010 | Apple Computers & Internet
When I turn my MacBook air on a blank White screen
Leave the Macbook air turned on until the battery goes dead. Then Connect to power and start it up. That should solve the problem. You problem was caused by not letting an update install in full.
Dec 16, 2009 | Apple MacBook Air
There is no display on the laptop and it does three short beeps three long beeps and three more short beeps
The video card or onboard video is dead. That is what that beep code is telling you. More than likely you will need it replaced. Sorry.
Jul 01, 2009 | Apple MacBook Pro Notebook
Apple MacBook Air Logo
217 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
