Question about Paxar Monarch 9830 Thermal Printer
Error Msg. "755" on Monarch 9830
Error message on our Monarch 9830 printer. 755 indicates print head open ( I think ). Print head is VERY not open. Have switched on and off. Installed new roll of ribbon and problems started afterwards. No problems before.
Should you wanna call, my cell is 704-244-1223
Thanks
David
    Novelist:
  • 113 Answers
I know that this is a bit dated, but there could be damage to the sensor that determines whether or not the ph is open. If that is the case, sending it in to the printer's repair depot will be the only thing to fix it.
200 Monarch lane
Miamisburg, Ohio 45342
Posted on Jun 25, 2010
    Problem Solver:
  • 7 Answers
If you look carefully there si a small magnet that touches another while when the printhead is closed which is known a sensor. when these to meet it tells the machine that indeed the print head is closed. lots of times one of these 'magnets' fall out and which fails to create the signal that the printer is closed
see if you can locate the area and inspect it
Posted on Sep 13, 2009
I get A fault code of 616. Cleaned print head. 618-744-9830 ext 281
616 is a dot shift error on the printhead. You need a new printhead.
Jan 27, 2011 | Paxar Monarch 9403 Thermal Printer
Printer error 3515
Kodak ESP-5 error message 3515....tried Kodak way but didn't work....could hear the print head attempt to move but couldn't...unplugged unit from power....opened to expose the print cartridges...removed small screws on sides and back of printer...gently pry open top....turn gears on right side with finger toward front several turns.....check and see if print head will now move to center....(I removed cartridges and print head so I could see the blotter under print head move to back position. Re-installed print head and cartridges.) plugged power cord back in and turned on...unit cycled and then screen showed normal....replaced screws in top panel.....printed test page...back in operation......Don't be heavy handed....plastic will break very easy I think when opening panel if not careful...
Dec 28, 2010 | Kodak ESP 5 Printer
Hi I have a C3485 all-in-one printer and I keep getting a error msg that it doesn't read the black ink cartridge
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 09, 2010 | HP Office Equipment & Supplies
MONARCH 9830 CHANGED PRINT HEAD AND ITS NOW SHOWING ERROR 909
Main board failure. There is no way to fix this error - you have to swap out the main board.
Feb 15, 2010 | Paxar Monarch 9830 Thermal Printer
I960 resume light flashes yellow 5 times 1 green
Five yellow flashes indicate that the printer doesn't recognize the print head, or thinks that the wrong print head is installed. You can try to remedy this by opening the cover, removing the ink tanks, then removing the print head (lift the locking lever). Check that the copper contacts on the back of the print head are clean, then reinsert the print head, lock it in, and reinstall the ink tanks. If you still have the error indication, the print head may be bad and need replacing. Contact Canon for your options on this.
Feb 05, 2010 | Canon Office Equipment & Supplies
Attempting to print labels from a Monarch 9855 printer and receiving error message: "Print Head error 768." Printer was working fine as of last Friday. We have other Monarch 9855 printers that are on other...
the problem is your printhead is bad . do a print test by presing both arrow buttons at tah esame time for two seconds, look fo rthe line that reads bad dots. if the value i sgreater than 000 yu have a bad printhead
jay
Jun 08, 2009 | Monarch Paxar? 9855 Label Printer
Problem to print label when Monarch is installed on network
101 : The format referenced by batch isn't in memory. (Try rebooting printer or closing/opening software)
005: Supply width is invalid. (Check your format data)
May 29, 2009 | Monarch 9855 Thermal Printer
Check Prinhead problem
This error occurs when the head has some damage. Check also that the head of the cable is properly connected.
Feb 18, 2008 | Paxar Monarch 9403 Thermal Printer
Invalid Command
Your 287 error has to do with an incorrect setting for printhead width, and in the control language that your software is sending to the printer, they either have something other than 0, or there is an invalid character like a carriage return or line feed being sent to the printer.
This is a difficult one to trace since the software sends the code and you cannot necessarily change what is being sent.
Please note that the software that you really should be using is PC Mate Plus, as this is a specialized printer for Paxar supplies called Care Labels. You may be able to cheat if your software allows you to select 300DPI print heads. If not, you'll need the software I suggest.
If you do not have this software, please contact Paxar (now Avery Dennison) at 1-800-543-6650 and ask to be connected to someone in technical support or if the customer service rep can offer you a link to a website for software download, or purchase.
Ohiotech
Nov 19, 2007 | Monarch 9855 Thermal Printer
Paxar Monarch 9830 Thermal Printer Logo
408 people viewed this question
Top Paxar Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Paxar Office Equipment and Supply Expert? Answer questions, earn points and help others
