Midea air conditioner MSCP12M4 need to know how to set the time. There does not appear to be a setting for the actual time??
SOURCE: My air conditioner keeps going on and off
I have the same problem too... I took off the temp sensor and let it hang out side,but it didn't worked, the cool air turns off still and it is helping to turn the whole room cold
Posted on Jul 19, 2008
  • 166 Answers
SOURCE: Timing settings
you may have forgotten to plug the fan sender unit in on the right side of the head if it is plugged in it may of failed witch is not uncommon.
as for the timing there is actually some small marks on the head it self and on the cam pulleys, also on the crank sprocket and the block if you cant find them i can send you a diagram.
if you can find the sender unit on the side of the head unplug it and earth out the plug with a split pin if the fans come on bingo get a new sender
good luck
Posted on Dec 14, 2008
  • 68 Answers
SOURCE: trying to set air conditioner
it shouldnt run for that long if it is sized right for the room in the first place. Does it not come back on after it runs for 30 to 40 mins?
sounds as though it is not the correct size for the room to me
Posted on May 02, 2009
dr_greg
  • 192 Answers
SOURCE: ai conditioner runs hot on cool setting
check the refridgerant level..must have the proper equipment to do this..or take to a service department at ur local dealership...also have them check for leaks
Posted on May 13, 2009
  • 384 Answers
SOURCE: thermostat set at 74, but air conditioner won't turnoff
Need to reset the lever sensitivitie( behind the cover) to a lower setting.
Posted on Jul 22, 2009
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
New Midea Air Conditioner system 3, does not seem to get cold air. Mode is on Cool and fan speed increase. Temperature at 20 degree.
More info needed. Is this a one-piece unit or a mini-split? Model number, any error codes, etc. More info will help
Jan 03, 2015 | Midea Heating & Cooling
How do i fix code E9 on midea air conditioner
I have a problem with Midea Brand Aircondition .display shows E9 code error,what is a solution
Dec 22, 2012 | Midea Heating & Cooling
Midea portable air conditioner leaking water from bottom
Do you have it tilted back slightly towards the outside? It will drain on the inside if not tilted properly.
May 05, 2012 | Amana Heating & Cooling
Changing temp readout on Midea Air Con Controller from F to C
  1. Make sure the unit is NOT on lock mode
  2. Press reset button for 2 second or until the Flashinf "F" appear on the temperature display or panel.
  3. Press Add button to change from Fahrenheit"F" to celius "C".
  4. Then press confirm and then cancel button to finish.
Jul 09, 2010 | Heating & Cooling
Problem of Midea dishwasher WQP12-9240A
yOU SHOULD BE ABLE TO USE THE SERIAL AND MODEL NUMBERS. The factory technician will ned those at the least.Look up the Midea on the internet and get the factory rep to explain the warranty or the dealer you purchased the unit. Good Luck
Jun 01, 2010 | Midea MPM-08CR-BB4 Portable Air...
What position on the pull switch is for everday cooling use
That would really depend on your desired cooling. i would say 24 deg C is a good setting. this would be like getting out on a cool day.
I hope this help.
Jun 18, 2009 | Midea MWF-12CR Air Conditioner
Washing Machines Logo
Top Washing Machines Experts
