Sony bravia kdl 40w firmware upgrade - Televison & Video
cene765
  • 787 Answers
SOURCE: Sony Bravia KDL-52XBR9
There is a error in TV.Count how many times blinking the red light.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" boards
Posted on Nov 16, 2009
Testimonial: "I also bought the Sony KDL-52xbr9 mine did the same thing with six blinks. I sent it back to to store. "
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
budmrtn
  • 11361 Answers
SOURCE: Can't seem to find a firmware update for my
The firmaware update is made because they found problems out in the field due to badly writen or not properly tested before it was released to the production line.
Posted on Dec 06, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
Software installation on a brand new sony bravia main board model KDL55W804A
It is very important that you install the firmware as soon as you replace the board. You can download the firmware as well as the instructions for free from the customer support website. Here is the link. Sony eSupport KDL 55HX750 Support . It is very important to follow the instructions as to not ruin your new replacement board. Good luck to you.
Jun 03, 2016 | Sony Televison & Video
Firmware update for sony bravia tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Firmware (Software) update procedure to many popular brand TVs and other devices are given in detail.
Mar 01, 2016 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How can I update my firmware on my sony KDL-46w3000 ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Firmware update procedure to many popular brand TVs are given with screen-shots.
Jul 27, 2014 | Sony BRAVIA KDL-46W3000 Television
How to do a complete factory reset of a Sony Bravia KDL-32s5600 ?
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
Jul 07, 2014 | Sony KDL-32S3000 32 in. LCD Television
KDL-32L4000 firmware
Contact the authorized service center for Sony. They will provide you software by USB.
May 30, 2013 | Televison & Video
Vertical blue stripe on my Sony KDL-40S4100
Was the telvision impacted? Usually a Blue line on various tv sets such as Sharp and Sony can also indicate a firmware upgrade being needed. Try that first, as to a panel if this is a panel we have in stock cost could be between $200-400 for the part that part cost from Sony coulb be double if you need to purchase new. Call or reference us if you need TV repair in Colorado 6_2_2012_7_06_05_pm.jpg
Jun 02, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Hello, This Sony KDL 40S4100 is only recieve NTSC signal, is there is any firmware or anyway that I can make it recieve PAL signal??? Thanks for your help.
This is another Sony KDL 40S4100
Anybody out there?
Sep 07, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
I have a Sony KDL-40V4100, constantly hearing clicking noises
Could be the power board or main board defective, but I suggest you do firmware update first. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 download the software.
May 08, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
OSD on Sony Bravia
Depending on the models of your units, there are some software/firmware upgrades for specific units to adresss this particular problem. Check the Sony website under support to see if any software/firmware upgrades are available.
Mar 19, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
