Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Washing machine is not spinning, and get...
By neptune on Sep 24, 2007
The washing machine fills, then gets stuck before the spin. If I then move the dial to spin and put it on spin it turns back and forth alittle but does not go into a fast spin. Also it appears that the door lock which ususally comes on after it is full of water is not coming on.
Comments:
Sep 24, 2007
- This is a maytag, neptune 9000 boutght in 1998
Same Problem
May 05, 2009
-   Washing machine is not spinning, door will not lock and there appears to be some type of black oil on the floor behind my washing machine.-   kyancey
Best Solution
posted on Sep 25, 2007
Helpful)
applianceboy
Rank: Guru
Rating: 86%, 69 votes
Check the maytag class action suit in reguards to the neptune issue. you may be entitled to an exseptional warranty call based on this reguards. there is a problem with both the wax motor and the control board.
Was this helpful?
Yes
No
Solution #2
Not Rated)
Washer_tech
Rank: Guru
Rating: 88%, 211 votes
the problem is your door lock. if the washer is not getting the signal that is locked it will not go into spin. the wax motor in the door lock unit is probably shot. i wouldreplace the entire door lock unit.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Buffalo12980
Rank: Wiz
Rating: 84%, 1054 votes
all electrical parts get their signals from the timer assembly. the timer operates of a small motor much like a motor from an ac electric clock. inside the mechanical timer are contacts which make and break according to a preset timer cam which advances throughout the timed cycle. if a contact is burnt or burnt off that function will not operate. if there is a mechanical hangup inside, the timer will not function. replacing the timer can be expensive at about $130. the timer schematic of a washer can be very confusing because certain functions happen the same time as others, while others are actually open. the timer cams and how they are connected appear on the timer open/closed chart. not much help I know but I've pulled many a hair out of my head troubleshooting a maytag.
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
need to purchase a new front load washer to replace my 7 year old frigidaire
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
Maytag MAV4057AWW top load washer will not spin hoses ok, water pumps out, but wont spin with or... (More)
Answer
washing machine is leaking at the bottom of tub where the tranmisson hook up to agitator.
Answer
1-overfills 2-also seem runs too long in rinse (we stpped it before running over tub 3-have maually... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
