Question about GE / Caddx Networx Programmable LCD Keypad NX148E
How to remove a zone from nx148e networx - GE / Caddx Networx Programmable LCD Keypad NX148E
We have an NX-148E keypad. Our building has 4 doors alarmed to the panel and the Chime sounds when any of the doors is opened. Is it possible to set the Chime only to sound when 1 of the doors is op
I am sure there is separate programming for each zone. You will need the manual for the system. Probably can get it on line. This chime feature usually comes from the factory with no zones programmed for reporting. Hope this helps
Oct 03, 2012 | GE / Caddx Networx Programmable LCD Keypad...
We have a Network NX148E which was linked to a central minitoring. Just wondering if this can be re programme to link to our mobile instead?
Hello
Yes you should be able to have the system call multiple phone #s.
I would recommend you ask your monitoring company to do this or make a change in your account.To add your mobile #
Once the alarm is set off they need to know first to dispatch police fire or ambulance.
Mar 29, 2011 | GE / Caddx Networx Programmable LCD Keypad...
I dont seem to get power to control panel. battery also not charging
These alarm panels receive 16.5 VAC from a small wall adapter that is wired into the keybus and labeled 'AC'. Have a certified alarm company or installer check your system for faults and get things in order.
Mar 02, 2011 | GE Iti Caddx Nx4 Control Panel 48 Zone...
Keypad message reading 12volt low battery on three wireless zones. changed out all batteriies and still getting message.
This could be referring to your battery backup for the control panel. Make sure your battery connections are secure and check the batteries' voltage with a multimeter. If it is showing less than 12 volts and has been connected to the control panel for more than 24 hours, the battery is bad and needs replacement. Contact your local alarm company and ask them verify the battery is bad, and they can install a new one for you right then.
Feb 23, 2011 | GE / Caddx Networx NX 8 Control Panel...
Can I adjust the volume on my GE Networx NX-148E keypad?
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
Feb 10, 2011 | GE / Caddx Networx Programmable LCD Keypad...
Hi, i'm using the Caddx NX4V2, the fire light flashes rapidly and no keys are working to stop it, i did read a manual that says the rapid flashing fire led means that there are problems ... how do i pin...
If you know the 'go' code ( default 9713 ), you can press *+90 to see the event log, which you scroll through with the arrow keys on the keypad (alpha keypads only). If that is not available, you will need to have a certified alarm installer come and check your system for faults.
Dec 13, 2010 | GE Iti Caddx Nx4 Control Panel 48 Zone...
Hi Liam here I just installed a networx nx4 and when powered up key pad has 1,2,3,4 flashing rapidly with service light on I was able to get rid of service light but zones still flashing And there is only...
This could be a supervision problem. If zone expanders, gsms, keypads, etc. are added to this alarm panel, you must enroll the device with the control panel. This is done by entering into programming mode ( * + 8 + {go code} ) and then simply exiting programming mode by hitting the exit button. The GE NetworX control panel and it's affiliated compatible devices will auto-enroll after about 15 seconds. The default 'go' code is 9713, but this is usually changed by the alarm company installer.
Apr 21, 2010 | General Electric GE NX-591E-GSM NetworX...
GE networX security command center keyupad is frozen. I have 2. We replaced the battery that was needed, but before that was done the keypad froze with a shimmering light in the fire zone and a yellow...
since you did not list the model I cannot be certain this will help you, however if it is the correct model then there is a service section on page 16 that should help. http://www.elvey.co.za/ProductFiles/d9726436-02b3-48ae-894f-0e03b2e6c072.pdf
Sep 30, 2009 | Computers & Internet
GE / Caddx Networx Programmable LCD Keypad   NX148E Logo
80 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
