Question about Harvard Rhino Play 9 ft. Wood Veneer Shuffleboard Table M01701W
I have a chip in the veneer playing surface of my shuffleboard table. Can it be repaired and how?
How many climatic adjusters do I need for my 16 foot shuffleboard table?
For tables between 12-16 feet long you will need 4 climatic adjusters. You will need to position two of the on either end, approximately 12 inches from the edge of the playing surface. The remaining two should be spaced equally between them (usually 3-4 feet apart).
Aug 20, 2012 | Sport & Outdoor - Others
I would like to buy a shuffleboard table for outdoor use. Are there specific tables for this or any table will do?
I recommend buying an outdoor specific shuffleboard table. They are better and enduring weather conditions. Here are a few sites for you to browse through; however I recommend doing a little comparison shopping of your own.
http://www.shuffleboard.net/12-cirrus-outdoor-shuffleboard-table.html
http://www.shuffleboard.net/9-metro-shuffleboard-table.html
Is it possible to construct my own shuffleboard table?
Of course it's possible; it just depends on your woodwork skills. Here are 2 sites - one for an indoor table and the other for a generic shuffleboard table. Hope it helps.
http://www.ehow.com/how_4472360_build-home-shuffleboard-table.html http://www.ehow.com/how_7297231_build-indoor-shuffleboard-table.html
How do you win in a game of table shuffleboard?
The object of the game is to slide your pucks (each player has 4) down the board into marked numbered areas without falling off. A final point goal varies depending on which variation game of shuffleboard you play; for instance a game of Knock Off plays to either 15/21 points while a game of Horse Collar plays to 51 points.
What is a climate adjuster?
A climate adjusture is used on shuffleboardtables to ensure the level playing surface. Basically the table legs areensuring the level but the micro adjustments can be made by the climateadjuster.
Jul 09, 2012 | Sport & Outdoor - Others
How to maintain a shuffleboard table?
First, you should make sure that you put thetable away from open windows and direct sun and you should also make sure thatthe room has climate control and that climate in the room does not fluctuatesmuch from season to season. The table itself is the most important element ofthe game and it requires the most attention and maintenance. You can learn allabout maintaining shuffleboard tables here: http://www.mccluretables.com/t-shuffleboard_maintenance.aspx
What is the official size of the shuffleboard table?
The official length of the playing surface shall be 20'8" long, and 20" in width.
Harvard Rhino Play 9 ft. Wood Veneer Shuffleboard Table M01701W Logo
580 people viewed this question
Top Harvard Sport & Outdoor - Others Experts
Are you a Harvard Sport and Outdoor - Other Expert? Answer questions, earn points and help others
