Epson m188b Printer isn't cutting the receipt paper as it comes out and it's causing an error. How can I fix this?
SOURCE: Epson M129H prints blank receipt
i need m129h driver
Posted on Apr 13, 2009
SOURCE: how to auto tear paper after printing receipt is completed.
I had the same problem, and after going through so many articles, I was getting the message but didn't know how to pass the escape codes. All you need to do is pass the ASCII code of the characters needed preceded by the ASCII code for Escape. In Delphi, we use Char(27) or #27. In my case I used ESC 105 Null and it worked. Here is my sample code, with Str being a TStrings class (A string array object) and the WriteTextFile being a procedure to write the Strings to LPT1 as plain text. Str.Add('*********END**********'); Str.Add(''); Str.Add(#10); Str.Add(#10); Str.Add(#27#105); WriteTextFile(dmMain.LPTFile, Str); any questions, holla me at gachugu@yahoo.com or igachugu@gmail.com
Posted on Jun 10, 2009
SOURCE: Auto cutter does not cut automatically
TM 220a and TM 220b should come with auto cutters
You have to unscrew the metal tab under the printer, you will find two sets of DIP switches. upper one is DWS 1 and the lower one is DWS 2. On DWS 2 you need to have jumper #2 ON. this enables or activates the auto cutter on printers. Good luck...
Posted on Jul 04, 2009
SOURCE: Extra Long Receipts
we have Star TSP 700II and it is doing the same. not just 4inches but sometimes it adds extra 20-30 inches blank space. I think it was due to incorrect paper size settings.
Why dont you to go printer properties->Device settings and change the Friction size..as well as set Pagecut to Partial.
Also change preferences under Properties, advanced and change papersize to what suits you .
pl let me know what happens soon
sean
Posted on Feb 27, 2010
podita
  • 324 Answers
SOURCE: Epson m188b paper
the choice is yours
http://search-manual-online.com/epson-u220-printer-manual-manual.html
http://www.pdfone.com/related/tm-u220-thermal.html
if this is good for then its good for me, please vote me
Posted on Mar 25, 2010
Why my printer is not able to cut recipt
Cutter blade may have some receipt paper jamming its movement. It is not a very powerful motor and easily jammed. Open the top and look closely for little cut pieces of paper. Clear out all the pieces and try to blow it out with canned air. Reboot system and check printer settings to make sure cutting function is set. Give it a try.
Mar 15, 2014 | Epson POS TMT88IV Thermal Receipt Printer
Epson PX650 not printing the full A4 page of my receipts, cutting off on right hand side
COULD BE THAT THE PAPER IS BIGGER SIZE THEREFORE CUTTING.NEED TO SAY FIT TO PAGE ON YOUR PRINTER DRIVER
Nov 18, 2013 | Epson Aculaser C1100 Printer
Epson m188b paper
the choice is yours
Mar 25, 2010 | Epson TM-U220PB Matrix Printer
M188B Model will only print when turned off then back on.
you should check all connection
change IF Board
or main board
Oct 27, 2009 | Epson Office Equipment & Supplies
Jun 08, 2009 | Epson TM-U220 Matrix Printer
Paper advances only 1 inch, cuts, no printing
I have problems with USB docket printers with certain packages how I get around it is I share the usb printer as a network share then I issue this command on the command line
NET USE \\COMPUTER_NAME\SHARE_NAME COMX:
where X is an unused comport. I then install the printer as a standard serial printer in the software package. I have had particular trouble with that model of printer and its solved for me in the past. Another note is if the computer is not on a network you can install a 1394 dummy connection that way the network is still accessible. Comment if you need help on that.
Dont forget to rate me!
Cheers!
May 06, 2009 | Epson POS TMT88IV Thermal Receipt Printer
336 people viewed this question
k24674
