Question about Liebherr KB4250 Refrigerator
Replace fridge door seal liebherr - Liebherr KB4250 Refrigerator
sdmc73
  • 121 Answers
SOURCE: I have just purchased a
the door may be twisted or the seal may need to be adjusted try a hair dryer on the seal it will heat it up and readdjust the seal-gasket
Posted on Nov 29, 2008
SOURCE: How to find part number of Liebherr fridge freezer
Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
Hope this helps.
Posted on Jun 08, 2010
  • 4793 Answers
SOURCE: Disgusting smell from my Liebherr fridge
use a syringe to blow clorine bleach down the drain hole.(the clorine will gas off and leave no smell after about an hour)
Posted on Jul 23, 2010
SOURCE: Fan not working, temperature too cold
You may need a man. Mine was doing the same, The sensor repair kit costs £35 the labour £60, both plus vat, so that was £109.25 in 2009.
Repair men seem thin on the ground and therefore his traveling time may add up. I believe, repair men pay for a course, and then charge like a wounded bull as they are the only ones that can do anything necessary
Posted on Nov 03, 2010
Hi, we have had a liebherr KI 2444 intgrated fridge/freezer since new, 10 years ago and it has been very reliable. We have noticed an increasing build-up of water gatering on shelves and items, which is...
Most likely condensation caused by a faulty seal. I am in the UK, no idea where you are. Try looking up espares or another spares company in your country.
Apr 16, 2017 | Liebherr Refrigerators
Alarm is going off (beeping) - ice accumulating on rear freezer wall.
hi check the doors seals if it closed perfectly and do not open the fridge or freezer door for long time because if you forgot one of the doors open it will make this problem and do not put hot or warm food inside most important to be sure that the seals stuck good when you close the fridge doors.
Sep 11, 2010 | Liebherr Refrigerators
Hope this helps.
Jun 08, 2010 | Liebherr Refrigerators
Liebherr Fridge Freezer fading door seal...
Look on e bay or kijji and see is anyone has one for sale That you could swap the door over .
Apr 06, 2017 | Liebherr KSv 4260
I have a Liebherr fridge which seems to be on permanent supercooling. It freezes fluids. I try setting a higher temperature but it just drops back to 4 C
4c is the std operating temp for most fridges.have you checked the door seals for fit if an airleak occurs fridge will try to maintain cooling.....freezing salads.
Feb 11, 2010 | Refrigerators
My fridge freezer is omitting cheesy smells from
Im still looking for the same problem and how to solve. Ive established it stagnant water in the drip pan at the rear. I keep cleaning it and intermitantley it comes back with water that looks like cheese curd in it........ Im going to call Liebherr as the fridge has been doing this since last year and is now getting worse but is only 2 years old.......
Feb 04, 2010 | Liebherr KES4260 Refrigerator
Ice keeps accumulating in back of fridge. We've tried cleaning drain but it doesn't seem to help.
If the drain is clean and there is sufficient space for air to flow around the food, the only thing left is to replace the door seal. It is allowing moisture to enter the freezer. The fan inside the freezer, actually burns the frost off of the food. If the seals are bad, it can never catch up.
Sep 17, 2009 | Liebherr Refrigerators
Our liebherr freezer door seal has broken, should this cause the fridge to warm up.....5 upto 17 degrees?
All sorts of things can go wrong. Warm air will be sucked in and typically there will be water dripping from the cieling. The compressor will also continue to run .Will almost certainly get an ice build up on evep. plate. Suggest replacement as soon as possible.
Sep 16, 2009 | Liebherr KTS 1534 Comfort Compact...
The freezer on my Liebherr fridge keeps filling too much with ice. The ice grows around the door and seal which makes it impossible to close properly. I inherited the f/freezer so I don't have the...
This sounds like moisture in being sucked in past the door seals. Remember, cold-- sucks temperature, (like a vacuum) and HEAT--- pumps away temperatures..So the warmer temp. are always being drawn in.. Thus, bad door seals, and need to be replaced --- cleanned---or repaired, but for now turn your thermostat or temperature up or the control knob back lower, (like from 7--to 5--ect. ect 4-to 2..)!
Sep 06, 2008 | Heating & Cooling
Liebherr KB4250 Refrigerator Logo
15 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
