Question about Honda Garden
The gasket is there.
BXD 2525 Comet Water pressure Pump. I e-mail a problem and the answer i got was that a gasket is missing. Check ok The problem again is that the hose is connected to pump and the wand hose is connected to pump turn water on and the water sprays out of the hose connection of the pump and no water comes out of wand when i press trigger. Start machine and the spray shoot out lightly out on wand but no pump nose at all. I was thing that the unloader may be stuck or bad could i be in the right area. or could you give me something i can check before i start buying and replacing parts. The machine is only 4 yrs. old but been used only about 8 to 10 times and that maybe a lot. I change the oil looking for discolor or siliver in oil like metal but found nothing but clear oil. If i had to replace the pump where can i get a good price to buy and what information do i need to no. How hard is it to put on.
thank you for all your help
Y a t'il un niveau d'huile dans la comet bxd 2525
L'utiliser cette pompe sans huile est une erreur fatale:
[PDF]COMET PLUNGER PUMP SERVICE MANUAL INDEX
www.cometpump.com/_images/support/Pump_Repair_Manual.pdfLUBRICATION: Make sure crankcase is filled with Comet Pump oil. Running this pump without oil will cause damage and void any warranties. Change the pump ..
Mar 14, 2014 | Comet BXD 2525 G Pressure Washer Pump
B&E pressure washer w/ comet 3540 pump
Things to check:
1) is water coming out of the bottom of the pump or is the oil in the crankcase high level and milky yellow. If so your seals are bad.
2) Your check valves might not be seating properly. A couple of fouled check vavles will cause either no pressure or pulsing pressure. A good inlet water strainer keeps foreign matter out of valves. But valves do wear out and get build up that keeps them from working right.
3) Your unloader valve might be worn or fouled. Bad unloader would usually show as low pressure ( but more than hose pressure) or low volume out the trigger nozzle.
Valves are your most likely problem.
Feb 17, 2014 | Comet Pressure Washer Hw3540s Triplex Pump...
Oil seeping from Comet BXD 2525 pump
out the drain plug ? Sight glass window ? Under the pump where the crankcase meets the pump head?
tighten plug, replace oring on sight glass or replace low pressure seals if near the pump
Dec 09, 2013 | Comet BXD 2525 G Pressure Washer Pump
Comet water oil
You have to take off the pump head. Here is the link to the service for comet pumps.
https://www.pwmall.com/PDF/CometServiceManual.pdf
Nov 03, 2013 | Comet GXD2527G Pressure Washer Pump
My GDX 2525 will not pressurize water. I have tried adjusting the calibration knob on to without success.
It could be that the linkage between the engine and pump is broken. Try the key on the drive shaft. This is a piece of metal that locks the pump shaft and the engine shaft. If it still pumps water the problem probably lies elsewhere.
Jun 08, 2011 | Comet Pump Pressure Washer Pump 2.5 Gpm,...
I have a Comet 4040 and oil and water mix is bubbling out of the red cap on top of my pressure washer. Can anyone tell me what repair kit I might need to fix this problem?
Hi this could be the oil and pump seals worn. Also make sure that you don,t have the transit plug in or the pump cannot breath. It should have a air vented dipstick.
May 21, 2010 | Comet GXD2527G Pressure Washer Pump
No water coming out of the pump
Hi
Is the pump working?
Some pressure washers need to suck the water out of a container, not pressure fed from a hose.
Check the filter for blockage.
Regaeds
Phillip
Oct 16, 2009 | Psi 2000 Pressure Washer
Oil for Comet pump
aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
May 12, 2009 | Comet GXD2527G Pressure Washer Pump
Garden Logo
118 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
