Question about Philips 26MF231D 26 in. LCD Television
TV Powers off after 30-45 mins
I have this TV in the 32 inch model and after 30 - 45 minutes the TV screen will make a loud static noise then the screen will turn black with some white on it and turn off. The TV will then reset itself and then do it again with in 60 seconds. Is the TV over heating? I just replaced the power supply board less then 2 months ago. Any help would be great. Thank you - Jeff
  • Anonymous Nov 13, 2007
    same problem with 26mf231d 26in lcd
  • Iain Searcy May 11, 2010
    Here is a tutorial on how to remove the back panel of the TV.
    http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
I had the same problem with my 1 year old 26" TV. I called Magnavox customer service, and they had me upload a new software driver to the TV - which didn't solve the problem. Then they suggested that I call the local Authorized Service Center - and they estimated that it would cost $200+ to fix the problem. But then I found the "remove the back solution" listed here - and it worked!
Thanks, you saved me at least $200.
Posted on Jul 20, 2009
  • German Isales
    German Isales Mar 17, 2011
    Hi all i found the problem i have the same lcd model #26mf231/37 Mainboard #313815866861 6182.2 , 6281.3 ,6285.4 All apllies Im a technician since 1990 and here is what i discovered. I opened the back cover and removed the metal casing i cutoff a rectangular box from the metal casing to expose most of the power supply and i also cut the same square box from the cover backside. bought a metal mesh so that the power supply can breath. Next i wanted to make sure my main board was good so here is what i did. I pluged in my soldering iron 30 watts then located a crystal board location 1H00 and i applied heat to it while the tv was on and sure enought it turned off that's where the problem is. Remove the main board and add alittle bit of new solder and walla. Let me explain the problem: The 1H00 is a crystal safety feature when it gets hot the solder around it contract therefore it looses connection is common is lcd/plasma T.V's heat is Evil in any component. Anyway once you have acomplish all of the above you should be good to go. Please email me and let me know how you made out with the T.V.
    Remember cold solder is the killer for all electronics
    Send your comments to: [email protected]
  • German Isales
    If you need pictures as to what i did to modify this set email me i,ll gladly email them to you.
    Thanks
Without the back cover though you can't wall mount it can you?
Posted on Dec 07, 2007
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
SOURCE:
Loud static noise when I turn the tv on
what tv what model what what ?? all detail is missing past a crystal ball ???? static noise is usually psu or eht sides
Nov 30, 2014 | Televison & Video
Vizio TV has intermittent white noise issues
If the TV is connected to a Set-Top box such as a cable box or Satellite box, try a new box, otherwise it would be a defective main board.
Feb 24, 2018 | Vizio E320i-A0 32 Class LED Smart TV
52 inch RCA Home theater-Sound is distorted/scratchy
I unplugged the tv for 5 minutes. When I turned it back on, I had sound!
Aug 01, 2009 | RCA 32V420T 32" TV
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
AKAI LCT3285TA static noise
Which input connections are you using?
Jun 07, 2008 | Akai LCT3285TA 32 in. LCD Television
Philips 26MF231D 26 in. LCD Television Logo
329 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
