Question about Lenovo 3000 V100 Notebook
UnExpected Shutdown, non overhating problem
Hello, I got a Laptop Lenovo 3000 v100, since 1,5 month, PC is experiencing some problems, suddenly shut down, I have no problem with overheating (I am running everest and monitoring this aspect). Could you please help me? I thank you in advance Kind regards, Marcelo Barrios
  • voobweb Apr 23, 2009
    the sudden shutdown happens only when running windows xp sp3, i have osx86, 2.6 linux and opensolaris working just fine on this same machine....
My Lnovo 3000 G 410 Fan sounding high and pc suddenly shut down
It seems like that your pc is old when you work on it procesdor heats and fans cools but in your case it is overheating your lapy need service open laptop and clear the dust near fan if you are a expert then apply cooling paste on processor head or change the heat sink
Feb 23, 2015 | TechFuel AC Adapter (ACNB90W2130) for...
My lenovo y410 laptop gets hot sometimes and shuts down automatically
Try to disassamble your laptop and clean the dust from it, and make sure the processor fan is working.
Computer have a mechanism to protect the processor from overheating that can damage them, soo it will shutdown automatically.
Nov 19, 2012 | Lenovo 3000 Y410 Laptop
MY COMPUTER SHUTDOWN WHILE IT HAS A 60%REMAINING BATTERY. UNEXPECTED SHUTDOWN. MY LAPTOP CANT RESUME THE PROGRAMS RUNNING AND UNSAVED DOCUMENTS AFTER THE UNEXPECTED SHUTDOWN HAPPENS ..WHY MY OTHER LAPTOP...
If the Computer restarts randomly, then the issue might be due to any damaged Operating System Files.
But, if the Computer shuts down randomly, it is due to the Processor.
All the Processors will be designed in such a way that, if there is any overheating issues, the Computer will shut down randomly.
The overheating might occur due to the malfunction of the Cooling Fan in the Computer.
As this is a overheating issue, it would be better to get the Unit examined at the Service Center.
Replacing the Cooling Fan in the Computer should resolve the issue.
Jul 05, 2010 | Computers & Internet
Suddenly shutdown my laptop what is a problem i
Hello my friend,usually laptops when are overheating because of the processor or graphic card they start restarting or shutting down.Was your laptop warm when shut down or you was watching video or playing a game?
Feb 06, 2010 | Compaq Computers & Internet
I have a lenovo laptop, 3000 G410. Recently it has a problem which it shut down by itself after I use it for 20 minutes. After the shut down, I turn it on and this time it work only 2 minutes and shut down...
This sounds like a overheating problem (a CPU thermal shutdown).
This is caused by a faulty fan or the heat-sink and fan is clogged with dust. Check the fan to see if it spins freely, if not replace the faulty fan. Check the fan/heatsink assembly and remove/vacuum the dust from these components.
Nov 08, 2009 | Lenovo 3000 Y410 Notebook
My lenovo 3000 C100 suddenly power off. Anyone
This sounds like an overheating issue. Make sure your vents are free of dust and debri by using a can of compressed air. Then try powering on listening to see if your fan is spinning. If it is not you'll need to replace it. If it is then make sure you are using the laptop on a cool hard surface rather than cloth or such. If you still have the problem then the most inexpensive fix would be to purchase a laptop colling pad to use underneath, usually $20-40 at most computer stores. Hope this helps.
Oct 12, 2009 | Lenovo 3000 C100 Notebook
Aspire 5630 - Unexpected shutdown!! This weekend, the laptop just shutdown without any warning! I switched it back on, and then after 30 mins, the same issue!!! I checked the battery, and was charging OK....
Depending on the age of the laptop, it could well be overheating. Let it cool down good, and try again. If that is the problem, you will have to clean out the cooling system with a can of air.
DO NOT USE AN AIR COMPRESSOR ! ! !
Mar 16, 2009 | Acer Aspire 5630 Notebook
Sudden off with out any warning
How did you clean your fan? How much stuff was in there?
The problem you're experiencing sure sounds like a thermal shutdown. Try using compressed air on both the fan's intake and outtake.
Do you know for sure the fan runs?
If that doesn't solve it, you may have to pop the case and see if you've got a physical break in teh cooling system between the fan and the CPU.
Dec 22, 2008 | Lenovo 3000 Y410 Notebook
Mouse Sensitivity Issue
If your laptop is Vista, this page should have a download for a Vista touchpad driver:
http://consumersupport.lenovo.com/lenovo/drivers/2412/50.html
If it's an XP laptop, try this link:
http://consumersupport.lenovo.com/lenovo/drivers/2412/313.html
If one of them works, let me know which one and rate appropriately. If neither of them do, we'll try something else.
Thanks.
Aug 25, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 V100 Notebook Logo
415 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
