Question about Dishwashers
Dishwasher water is not coming in my dishwasher and how do i dismantle the spray arm at the bottom to clean
  • delesse May 16, 2008
    Ny dishwasher is a galaxy model# 665.110713091 serial #3505627
    The sprayer arn is not turning around. We were told that if we remove the sprayer arm and check the pump for a possible clog and remove the clog it should work
    how do we remove the sprayer arm?
  • mtdoc007 Sep 29, 2008
    I have a Roper dishwasher RUD4500DB3 that I washed a jar with the paper label attached. The dishwasher now does not drain well. The manual says that the pump may be clogged with paper. How do you remove the sprayer arm to check the pump. Thanks
Whirlpool DU5000W
Posted on Dec 28, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
If no water is coming into the machine at all it is a problem with the water valve, not your spray arms. as far as the spray arm goes I need the manufacture and model number to explain what to do.
Posted on Sep 25, 2007
-+the top arm is not turning in my washer Model #GU1200XTLB2. I have removed it and cleaned it and it is still not turning. Can you offer any suggestions? Thank you,
Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
homeguides.sfgate.com > Foreclosures > Other Foreclosures
Remove the lower tray of the dishwasher to freely access the spray arm. ... Although spray arms are directly powered by the water pump for the dishwasher, not all of ...For best use, clean the filter and pump at least a couple of times per year. .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell Your ...
Dishwasher Cleaning - Top Rack Doesn't Clean - YouTube
? 12:57
https://www.youtube.com/watch?v=75DB9cyPYO0
Feb 7, 2013 - Uploaded by Dogwood Tales
With that said, I'm working on more such videos for household maintenance and repairs and ... In my case the bottom rack of thedishwasher was cleaning well, but the top rack of thedishwasher was not coming out clean at all. In fact ..... How to clean and replace Dishwasher Spray Arms - Duration: 2:07.
How To Fix A Dishwasher Not Cleaning Bottom Or Top Rack ...
Jan 12, 2016 | Dishwashers
Spray arms not working
Hi frustrated in Raleigh,
I understand that the spray arms are not moving or spraying water, even after you have cleaned the screens and arms. What might be happening is you are not getting enough water pressure to the dishwasher.
The hot water line to your dishwasher must provide water pressure between 20 and 120 psi.
Low water pressure may occur when laundry or showers are in operation.
Wait until water use is reduced before starting dishwasher.
If you are still noticing that the spray arms are not moving or spraying water, I would have a local Authorized Technician come out to see what exactly is going on with the spray arms of your dishwasher.
-Best Regards-
Jan 06, 2014 | Frigidaire FPHD2491KF Dishwasher
My dishwasher is not working water is making to the dishwasher and is getting pumped out but it is not going through the jets
There's aspray arm at the bottom of your dishwasher--it may have a tall spray tubemounted to the center of it. There may also be a spray arm located directlybeneath the upper rack of dishes and/or above the upper rack. If debris is blocking the holes inthe spray arms where the water comes out, it could cause cleaning problems.Regularly inspect each of the spray arms and clean out the holes as necessary.
May 13, 2011 | Frigidaire Dishwashers
Dishwasher is not cleaning top rack
If the top rack is not getting clean, then either the spray arm holes are slightly plugged and not allowing enough water flow to the machine. The water coming from the arms also makes the arms moved in a circular direction which also helps in cleaning. Either the arm is plugged and not allowing water flow or the arm is stuck and not rotating. I would use a toothpick and clean all the holes first. Then try it. Try and spin arm by hand and make sure it spins very easy and freely. If not, replace it or dismantle it and clean it really good so there are no clogs and it can spin easily.
Dec 31, 2010 | Jenn-Air 24 in. DW731 Built-in Dishwasher
I have a miele advanta g2170scvi dishwasher. it has three problems -- the top washing arm comes off its base every few washes; it doesnt clean well and there is an odor coming from the dw even tho i have...
Hi dear.Please do the following try to solve the issues.Please clean the bottom & upper spray arm.They must been blocked. That makes a lot of water pressure on top spray arm & it comes off.Also blocked spray arms resulting poor wash performans. With the odour,check the drain pump.It's non return valve.It should work properly.Also check for siphoning.That can cause bad odour.Please click the link below for meore help from it's user manual.Section: Cleaning & Care Page 42. I hope that helps.Thanks.
http://www.mieleusa.com/manuals_pdf/Residential/Dishwashers/English_manuals/Operating_Instructions/G1180_2170_2180_us.pdf
Jul 08, 2010 | Miele Advanta G2170SCVi Dishwasher
Gritty film left on almost all dishes, rinse aid level seems to always remain at full, but apparently not rinsing well.
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Mar 11, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
sounds like no water going into the machine. you may need a water inlet valve.
Nov 07, 2009 | LG Dishwashers
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
Not cleaning on top rack. Pump, fill tube asm. & spray clean. Has any seen if this issue could be the deverter motor in the pump or the control board?
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
Apr 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Bosch dishwasher - top row of dishes do not get clean
There is a screen that you can remove from the sump of the dishwasher to clean. Just twist it to the left and pull it out. I have some tips that you might want to check out if this does not resolve your problem.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwashers Logo
235 people viewed this question
Top Dishwashers Experts
