Question about Whirlpool Refrigerators
Old refrigerator 2188772
Ice won't come out chute in door
watugot
  • 290 Answers
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
peyton32034
  • 410 Answers
SOURCE: Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Posted on Dec 11, 2007
peyton32034
  • 410 Answers
SOURCE: replacing door chute on kenmore refrigerator 57562792
first of all unplug the refrig.
look at the bottom of the disp cover and you will find 2 slots for you to slide in a flat tip screw driver. carefully pry the bottom of the cover loose 1 side at a time.once this is loose, either remove the 2 screws that hold the switch housing in place or release the clips ( depends exactly onwhich model you as to wether there are clips or screws) once this is free remove the plastic funnel, by this point you should see how the chute door removes.
a few notes the disp cover can be hard to remove but it will come loose also reinstalling just hit it firmly over each clip witht he palm of your hand.
good luck..
Posted on Dec 19, 2007
  • 2427 Answers
SOURCE: Ice Dispenser problem on KitchenAid KSCS25INSS00 Refrigerator
You can download the repair manual or service manual for you Kichen Aid which you can find by using goolge just type
SERVICE MANUAL KITCHEN AID (model) Brand
and google it
here is a useful forum that contais extra information and some quick fixes http://www.applianceblog.com/mainforums/showthread.php?t=7374
Posted on Jan 02, 2008
peyton32034
  • 410 Answers
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Posted on Feb 18, 2009
Outlet of ice tray ices up, also ice on door below ice maker. I clean it and ice is back in less than a week, whether we use ice or not.
What is the model number? Sounds like the ice chute door is sticking open and causing the refrigerator to run all the time while warm air is drawn through the ice chute door opening.
Appliance 911 Sea Breeze
Oct 01, 2015 | Refrigerators
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
How do I replac the clear plastic cover over the ice shute on the
order the chute assy old pull out and down holding the lever as to not break it other snaps in reverse order
Aug 19, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Door dhute not opening to let ice fall
on the right hand side of the door chute there is a little metal barrel that needs to be attached to the end of the arm that holds the ice door. this is attached to the spring that opens and closes the door chute.
Apr 16, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice chute door on maytag refrigerator
the door is opened by a solenoid. it is bad or it is not getting voltage due to bad control or wiring
Apr 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Frost on ice maker
look at the chute where the ice comes out the door and see if the door in there is sticking open and leaking air in some times it helps to hold a flashlight on the out side aimed up the chute while lookin down on the inside
Dec 31, 2007 | Whirlpool GS6NBEXR Side by Side...
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
