I have a fskuvn single lnbf to complement my panasonic freesat tv which i was told by maplins that i needed in order to recieve hd broadcasts.the normal dish set up picks up the sattelite o/k & the pictures are o/k but when i remove the standard lnb & fit the fortec i get nothing at all can you help by telling me how to set up the fortec
    Brigadier General:
  • 3,917 Answers
Will my westinghouse tv work in the uk in conjuction with a bush hd freesat box?
Both the tv and the Bush HD freesat box was bought in the Euoupean union?Wright?Yes,it will work together with no problems,both the tv and Bush HD freesat box both are recieving the same tv incomming broadcasting signal in PAL signal frequencies will be compatible.
Oct 27, 2011 | Westinghouse TX-47F430S 47 in. LCD TV
Need a master code to reset my dtr94 hd freesat tv reciever/recorder
From memory you need to get the channel list up then press green to unlock each channel in turn if any have been locked.
Aug 08, 2011 | Sagem PVR 6280 Freeview DTV Receiver /...
How does it help to have a Full HD LCD TV?
Hi - welcome to Fixya,
There is no advantage in buying a Full HD (1080p) TV if you are only using it for watching TV. Currently, there are no Full HD television broadcasts and there are no plans to introduce any. All UK HD channels currently broadcast in 720p resolution whether they are on Sky, Freeview, or Freesat. Therefore, any TV that is described as 'HD ready' rather than 'Full HD' will display all HD channels at maximum quality or resolution.
The advantage of Full HD is when using them with Blu-ray DVD players, gaming systems, e.g. Sony Playstation, or for playback of media files from your PC. These systems output at 1080p / Full HD (but only when connected with an HDMi cable) and you would need a full HD TV in order to get the best quality / resolution from these systems. However, you don't need a Full HD TV to connect these devices as they can all display their output on a 720p HD Ready TV.
The main disadvantage of any HDTV (1080 or 720) is when watching standard definition (SD) broadcasts. Full HD TVs have 1080 horizontal display lines, but SD broadcasts only have 540 horizontal lines. When watching SD channels on an HD TV, the other 540 lines, i,e half of the picture, are being created by software within the TV - known as 'Upscaling'. Upscaling requires processing by the TV which takes time and fast motion can seem blurred or blocky/pixellated as a result. Higher end TVs have faster response times (0.5ms or less) which minimises the pixellation so this specification is important when selecting an HD TV for purchase.
Hope this helps.
Regards,
BElectric
Nov 18, 2010 | Samsung Televison & Video
Dear Expert, My elderly parents have just purchased a Bush single scart socket Freesat viewer to use with a LG HD ready TV etc.... I have installed this successfully and it was working perfectly. Now...
first thing to check is the tv working in its old mode of analouge tv.
if this is instant and the slow start is with freesat box.this is probably faulty .
does the tv have freeview built in this is worth checking .
Aug 17, 2010 | Televison & Video
HOW TO GET HDTV FOR SAMSUNG WS32Z308P
You will need an HD receiver (Freeview HD, Freesat HD or Sky). For Freeview HD you'll need to check whether it's being broadcast in your area yet. Check the freeview site
May 01, 2010 | Samsung WS32Z308P 32" TV
Can i set up my blu ray recorder DMR-BS750 without
The purpose of that freesat to bo able to record/playbak 2 channels at the same time. But you still need a satellite dish pointing to the satellite in the sky so it can work.
Jan 13, 2010 | Panasonic Televison & Video
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
No sound on hd tv thru freesat
HDMI to DVI adaptors do not always support audio.You have to run seperate audio into the TV.
Jan 12, 2009 | Televison & Video
Unable to get sky on panasonic tv
You cannot drive both from a single cable. You require a dual LNB fitted to your dish (replacing the single LNB). This has two cables out , one to sky and the other to the TV. If you have your own dish this should not be a problem.
Jan 09, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
I have just bought a panasonic viera 42" tv. How can you get the HD working? It says it has freesat and HD built in but do I need to buy anything else to get this working?
no, just plug your anologue aerial into it and go into tv's menu and into setup then tv installation and it should take you through it step by step
Jul 23, 2008 | Panasonic Televison & Video
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
