Question about Brother HL-2030 Laser Printer
On power up all lights continue to flash
The manual suggest the machine be taken in for service, however there is no service station in Nigeria, I have also just changed the orint catridge with same result.
  • WiPer May 11, 2010
    All lights flashing means a "service" error has occured which usually requires an engineer to fix.
    However, if you press on hold the "GO" button the lights will stop flashing and the machine will light one or more of the other lights. Once you give this information I can tell you what the actual fault is.
    Scholar:
  • 35 Answers
Hi Mate,
i posted to another thread on here a while back about this its either a temporary problem where the printer has experienced some sort of "shock" that has put it into a stunned state and just needs switching off and leaving for 10 - 20 mins then plugging back in OR from experience the fuser unit is knackered and needs replacing.
here is a link to the brother site that gives the meaning of the lights, but as you already mentioned it means a service call.
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000100/000070/faq000170_005.html?reg=eu&c=gb&lang=en&prod=hl2030_all&Cat=6
If it is the fuser unit thats knackered it can be replaced but refurbished units tend to be more expensive than the cost of a new printer..
hope this helps.
Posted on Aug 28, 2009
Answering machine on light keeps flashing but does not turn on unit
The headset(s) and the base station need to be re-sync.
Check the bottom contacts (base and headset) and let them sync (3+ minutes) OVER-NIGHT if the headset are low on battery.
This will sync the security code.
Jan 16, 2014 | Panasonic KX-TG1031S DECT 6.0 Expandable...
Hp 500 ploter adjustment karne pra 22:10 errer cord ata he
System error 21:10 is generated when the printer has detected a fault in the Service Station. Causes of this error can include the Service Station or Carriage. Follow the steps listed below to accurately troubleshoot the issue, and replace the appropriate parts.
Part Description Designjet 500 Models - C7769B, C7770B, C7769C, C7770C Designjet 800 Models - C7779B, C7780B, C7779C, C7780C Service Station Assembly (Required) C7769-60374 C7769-60374
    NOTE:If Removal and Installation instructions are needed for reference during any repairs performed, refer to the HP Designjet 500 and 800 Series Service Manual available on the Computer Care Web site for review or download. Troubleshooting steps If any of the troubleshooting steps listed below solve the problem, attempt to verify printer functionality (instructions listed below). If functionality is verified, no additional parts should be replaced.
      NOTE: The printer's current firmware revision must be A.02.04 or higher for a new Service Station to work properly. If firmware is lower than A.02.04, download the newest available firmware before continuing with the remainder of this document.
      1. Turn the printer off, then on to verify error. If no error attempt to verify functionality.
      2. If the error appears or problems persist, continue with the remaining steps.
      3. Follow the steps directly below to unlock the Carriage from the Service Station:
        1. Highlight the Set-Up menu and press the ENTER button.
        2. Press the UP arrow and ENTER buttons simultaneously and press the ENTER button.
        3. Highlight Service Utilities and press the ENTER button.
        4. Highlight Unlock Carriage and press the ENTER button.
        5. Unplug the power cord from the printer.
      4. Manually move the Carriage assembly out from the Service Station area and check for obstructions (remove as needed).
        NOTE: If you are unable to release the Carriage by the previous process, remove the right end-cover and locate the main Service station gear (as pictured below in Figure 1) and rotate it counter clockwise approximately four revolutions. The Carriage assembly should now be free from the Service station. Figure 1: Service Station Gear
        1. If an obstruction is found and removed, plug the power cord in, turn the printer On and attempt to verify functionality.
        2. If no obstruction was found or the problem persists, continue with the remaining steps.
        3. Disconnect the power cord from the printer.
        4. Remove the right end-cover from the printer.
        5. Open the top cover and manually move the Carriage to the left so that it is not over the Service Station (refer to Step 3 for instructions).
        6. The Service Station flag should be at about a 45-degree angle as pictured below in Figure 2.
        Figure 2: Service Station flag correctly positioned
        1. If the flag is correctly positioned continue with Step 16.
        2. If the flag is not at a 45-degree angle, press in gently on the bottom of the gray and rotate the bottom of the flag to the right (toward the back of the printer) until the top of the flag clips into the tab on the Service Station. The flag should stay at about a 45-degree angle.
        3. Plug in the power cord and turn the printer on.
        4. If no error appears, attempt to verify functionality.
        5. If the error reappears continue with the remaining steps.
        6. Turn the printer off and disconnect the power cord.
        7. Replace the Service Station assembly (refer to pg. 8-52 of the HP Designjet 500 and 800 Series Service Manual).
          NOTE: The printer firmware must be upgraded to A.02.04 or higher for the new Service Station to work. The new Service Station does not have an Aerosol fan and older firmware will check for the Aerosol fan, thus causing another system error.
          1. Following replacement, turn the printer on and verify functionality as instructed below.
          Verifying printer functionality
          1. Turn the printer on.
          2. Allow initialization to complete.
          3. Load media into the printer.
          4. From the main front-panel menu, select the Ink menu and press ENTER.
          5. Select Troubleshooting and press ENTER.
          6. Follow the instructions on the Front panel.
          7. Following a successful troubleshooting print, functionality is verifie
Sep 16, 2013 | HP Hewlett Packard Designjet 500 42" Wide...
Panasonic TC-P50G25 sudenly stopped working the Red light flashes for 7 times and takes a pause, this continues
Its an error code that likely indicates a power supply problem.
Suggest you Google the model number with "7 blinks" "error codes" or "service manual".
May 04, 2012 | Televison & Video
Error code 21:13 restart the printer if the problem persists,call hp support
It all depends on the machine but typically all the 21 errors relate to the service station. this is the part to the right of the machine that "caps" the carriage and print heads when the carriage parks after a print. 13 refers to power cycling the machine to reboot it. If you need more precise info you will need to post the model and more info.
Aug 25, 2011 | HP Designjet T1100ps Printer
When I power up my HP 1220C printer, the power light goes on, it makes some noises and turns the drive rollers. Nothing else - the cartridges stay over to the far right. Then the feed rollers stop and the...
IT COULD BE THAT THE INK SERVICE STATION CANNOT MOVE BECAUSE OF WATE INK.ALSO ADD SOME SEWING MACHINE OIL TO THE SILVER SLIDE BAR THAT THE CARIAGE RUNS ON.DONT GET OIL ON ANY OTHER PARTS
Jun 15, 2009 | HP DeskJet 1220c/ps InkJet Printer
Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Feb 27, 2008 | Cuisinart Programmable Espresso Maker
36 inch wega trinitron
If a red light flashes for more than a few minutes,disconnect and reconnect the power cord.
Check the TV/VIDEO settings
make sure you have inserted the batteries correctly to remote control.
Try another channel to rule out of station trouble.
if the problem continues may be a power supply problem.
good luck ! please dont forget to vote if this suggestion is helpfull.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
All available lights on printer are flashing
More or less your printer fuser has gone bad. Replace the fuse. I suggest that when buying a printer you don't with dell 1710N these printers gives a lot a problem. I work with them every day at work.
I suggest that you go with HP.
Oct 09, 2007 | Dell 1710 Laser Printer
Machine emits continuous high pitched bleep and power light flashes blue/red
If working OK, probably means that the temperature alarm goes off because is getting hot the PC. I suggest to check why is that happening. All fans working OK? is the CMOS temperature alarm set too low? check your motherboard instructions booklet- It will tell you what the beeps mean probably in the last pages. Good luck
Sep 28, 2007 | Sony VAIO PCV-RX511 PC Desktop
Brother HL-2030 Laser Printer Logo
284 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
