Question about Dryers
Hi I have a roper dryer model is REL3612BW2 it will heat but the drum wont turn?
  • 490 Answers
The belt or the motor is bad
Posted on Apr 23, 2009
The dry wont run on high heat cycle but will run on the low heat cycle
Could be the Hi Limit Thermostat causing problems. There are over 350 Roper Dryers. Not much can be diagnosed without knowing the actual model number of your dryer. Please drop a comment with full model number. You can view the parts by selecting the correct model from this site.
RoperDryer Parts
Sep 02, 2014 | Roper Dryers
My Roper rel3612bw2 will only warm and not get hot. The heating element was replaced around three years ago. Could it be the heating element again or a thermostat control or something else?
I would disconnect the vent tube and run the dryer and see if it gets hot, if it does then it is a restricted vent. If not then I would check these items:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Jan 29, 2011 | Dryers
I have a roper dryer (REL3612BW2) that will not turn on.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Here is a link to the part you will need. Below is a video to walk you thru the repair process for the switch.
Dec 31, 2010 | Roper Dryers
Roper dryer model REL4434AWO has stopped spinning. Heating element works. Belt seems secure around drum.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 18, 2010 | Roper Dryers
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Roper Dryers
Dryer will heat up but drum will not turn. Unable
Good day,
Sounds like a broken belt, Excellent tutorial on changing the belt on the link below.
Caution: Some models used a very poorly designed belt tensioner. If the tensioner is that style, replace it while purchasing the belt.
Appliance parts house counter men are well aware of the problem. The Roper line is made by whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 04, 2009 | Roper REX4634KQ Electric Dryer
I have a Roper Dryer Model REX3514PQO. The dryer
Sounds like you have a broken drum belt.
If you have to replace your drive belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the belt is not broken, then I would check to see if the timer switch is working properly, if not then you may need to replace it.
Good luck,
I hope this helps
Oct 06, 2009 | Roper REX3614KW Electric Dryer
Roper dryer model res7648kq0. wont turn on or heat ?
On the back side of the dryer sits the heater and various safety clixons. Any of them that would be OPEN ( no continuity) would be the problem. Here are some repair pictures
Jul 25, 2009 | Roper RES7646KQ Electric Dryer
Dryer won't dry
hi i think the motor is unstable so the drying ability is decresing check and service it
Sep 10, 2008 | Roper RES7646KQ Electric Dryer
Roper dryer
what do you mean wont cut off ?? the heat?? the drum? was this on the top part of the heationg element?
Jun 09, 2008 | Roper RES7646KQ Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
