Question about Nikon D70s Body Only Digital Camera
Nikon D70s won't power on
I have a D70's that is out of warenty. The problem is that the camera will not power on. It has never been dropped or misused, just no longer power on. I have tried new batteries, swapped charger, just to rule out these as the problem, any suggestions? :-) My Nikon D70s suddenly decided not to power on!! I bought it 1.5 Years ago and never dropped it nor miss used it... This happened right after I changed the lens!! Tried changing but the problem persists!! Any suggestions?
Where you insetting batteries the both point clean once and try....
Posted on Apr 23, 2009
Self timer in nikon d70
Hello. I have a Nikon and it is a great camera. here is the owner manual for your D70. Go to page 105 and 106 to use the self timer.
http://www.nikonusa.com/pdf/manuals/dslr/D70_en.pdf
please rate my answer as very helpful. thanks, Joe
Apr 26, 2010 | Nikon D70s Digital Camera
My nikon d70 says that file does not contain image data
If the memory card came from a different camera and inserted into the Nikon D70, the error message will appear. Just format the memory card with the D70 and the error should disappear.
Hope this helps.
Andrew
Feb 05, 2010 | Nikon D70s Digital Camera
Nikon d70 digital camera wont come on when switched on
I had the same problem. Camera had to be sent back to Nikon repair depot.
Jun 10, 2009 | Nikon D70s Digital Camera
Camera will not power up changed battery just went dead Nikon D70
Are you getting any power from it? How about an error message?
Try blowing some compressed air into the battery chamber. There might be some debri or dust in there. Try replacing the battery to see if that solves it. (Someone you know must own a D70).
Apr 20, 2009 | Nikon D70s Digital Camera
ERR message on my D70
YES THE SEQUENCE MOTOR IS BAD AND THAT CAUSES THE PROBEL
Oct 27, 2008 | Nikon D70s Digital Camera
Nikon d70 camera
switch off the camera.Remove the battery from the camera,after two minutes reload the battery.Switch on ok?
If not, using the reset option you can correct it.
If not, if you have warranty leave it with seller
Mar 28, 2008 | Nikon D70s Digital Camera
Nikon D70 Digital camera
More than likely you have a defective switch, which should only be replaced by a Nikon authorized repair facility, since opening the camera to repair / replace it yourself would void the warranty. If you can't find your warranty papers, warranty information is available from Nikon.com.
Dec 25, 2007 | Nikon D70s Digital Camera
NIKON D70
The higher the ISO setting the more grain in the photo. Have you somehow set the ISO to say, 1600? http://www.nikondigitutor.com/eng/d70s/select.php?menu=1&sub=b11&num=12 Select ISO setting this way: http://www.nikondigitutor.com/eng/d70s/select.php?menu=1&sub=b05&num=10 Are you shooting in low-light situations (typically indoor)? Try shooting bright scenes and Auto mode, or manually set ISO to 100 or 200 and see if noise persists.
Apr 02, 2007 | Nikon D70s Digital Camera
Problem caused by defetive circuit part or electronic component within the camera. Typical repair charges may run $175-275. Damaged parts must be replaced to cure the problem.
Mar 13, 2007 | Nikon D70s Digital Camera
Nikon D70s Body Only Digital Camera Logo
171 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
