Question about Panasonic TH-42PV8H 42 inch MultiSystem Plasma TV
Th-42pv8h power led red 2 blinking - Panasonic TH-42PV8H 42 inch MultiSystem Plasma TV
  • 61 Answers
SOURCE: Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Posted on Oct 09, 2008
SOURCE: red light power blinking
power supply problem this can be done by a professional tv repair
Posted on Sep 12, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-C42HD18 Blinking Power LED (7 times)
NEED SD OR SU OR SC BOARD REPLACED
Posted on Sep 21, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-50PZ80U tv, error- 2 blinks
1. Reseating the connector P25 may solve the problem. If it does not.
2. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
3. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown.
Posted on Dec 06, 2009
  • 11800 Answers
SOURCE: I have a panasonic plasma
The factory diagnostic for an 8 blink error code is: Driver SOS 3 SS-Board / SS2-Board; SS FPC Detect; SS Energy Recovery Circuit. Basically it means that the current absorbed by the X-Sus board is too high. It looks like this
http://www.discount-merchant.com/PANASONIC-TNPA3544-X-Sustain-Z-Sustain-Board-p/1042654.htm
You will need to open the tv and check the connections to this board and all the components on it. Also check the filtering capacitors from the power output line that powers this board.
If you can't find anything wrong then the entire board will have to be replaced.
Posted on Aug 06, 2011
TH 42PV8H A MY TV POWER NOT ON RED LED 2 TIME BLINKS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Mar 16, 2016 | Panasonic TH-42PV8H 42 inch MultiSystem...
Panasonic LCD TH-L32C2OM when I on the above lcd tv green led blinking and within few seconds red led blinking 4 times
Looks like a power supply trouble or capacitors not good. Has to be open and check by a pro. Good luck,
Serge.
Dec 27, 2015 | Panasonic Televison & Video
There is a blinking red light next to power button.Panasonic tv will not turn on.
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Hopefully it eventually stops blinking after unplugging set from the outlet, otherwise claim your Nobel Prize for wireless energy transmission.
Oct 17, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
12 blinks on th-p42x20m
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 13, 2014 | Panasonic Viera TH-50PZ85U Plasma TV
Not turning on led blinks twice
If your model is the TH42PZ80U 2 blinks is indicating to replace the D Board (Logic) That model used two different versions D board. www.tvcircuitboards.com has both versions and can assist with determining which version your model uses.
Feb 18, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic model th42pz77u no pic, no sound, blinking red light ten times
9.2. Power LED Blinking timing chart
1. Subject
2. Contents
26
TH-42PZ77U:
There are different patterns for blinking light...
10 times indicate DG board problem - SUB 5V SOS, MAIN 3.3V SOS, DTV 9V SOS and Tuner Power SOS.
Aug 16, 2010 | Panasonic TH-42PZ77U TV
Red power light flashing..no picture
Count the blinks of the led. The number of blinks gives an idea of which board has failed let me know
May 01, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Red light power blinking
Sep 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic pt-52lxc66 power light blinks
There are actually two red leds present on your tv and depending on which one is flashing is going to tell you what to replace. 3X on the Temp led will point to a faulty thermistor and you would want to replace this part. If the 3 red blinks are the lamp light than this is a error on the iris position and you would need to have the optical block replaced.
Josh
Feb 09, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
TV turns off aftering powering up. red LED flashes 3 times.
3 red blinks means th lamp door in not on. if you have installed the lamp door corectly and it still does this solder all three pins together on the door switch.
Oct 08, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic TH-42PV8H 42 inch MultiSystem Plasma TV Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
