Webcam does not work
It software says, used by another program even there is none
    President:
  • 8,637 Answers
Normal 0 This ptogram will eliminate your problem of the camera being busy or being used by another program. Really works great.
Double click on this site http://download.cnet.com/SplitCam/3000-2348_4-10500269.html
And then click on Download Now (3.5MB)
  1. Install Splitcam saying yes to everything during installation including the any warnings.
    2. Then run the Splitcam program by double clicking the downloaded program.
    3. Clicked on "Video" at the bottom right of the program window and selected your cmera.
Note: This will result in your camera being switched on and viewable in the
SplitCam program.
4. Opened up Skype (or other messengers) and go to "Tools" then "Options" then "Video settings."
5. Also setup your “Audio” while you are there.
6. Selected "SplitCam Capture" as my webcam, then click on save.
7. Webcam image will appeared in Skype or what ever messenger you are using.
Hope this Helps. Bud
Posted on May 01, 2009
My daughter is using logitech and my son is using skype. After visiting with my daughter on logitech, my son can't see or hear me on his computer, but we can see and hear him. If I go back to logitech and...
You should be able to go from one program to another but you will need to reboot the webcam software as its not unusual for webcam software to remain hooked up to a previous program even if you exit from it correctly
If the webcam is plugged into the USB just unplug it - when its not running - and wait a couple of seconds before plugging it back in
If it's a built in webcam - you will have to restart your computer or navigate to Device Manager - open the Imaging folder -right click on the webcam text and disable and the enable the webcam after a couple of seconds
Jan 05, 2011 | Logitech Computers & Internet
My webcam is not working it keeps saying that "the webcam is in use by another application" even though it's not being used
Webcam software can remained hooked up to a previous program even if you exit that program correctly
You need to reboot the webcam software by unplugging it for a few seconds and then reconnect
Failing that, have a look on the Logitech Forum where software conflicts have been discussed
Launch the Logitech toolbar and click on the Help menu ( Question Mark icon)
Aug 24, 2010 | Logitech QuickCam 961464-0403 Webcam
My camera is not working.it says in use by another application. I dont know which application is using it actually none of those apps are turned on.How can i fix it?
It is possible your Startup files contains Skype, VID, PhotoBooth, or some other program that hijacks your webcam. Even if you don't have those programs running they may keep you from using a different application. You will have to manually go through any type of program that could use your webcam and turn off the camera, and/or remove those programs from your Startup menu.
May 12, 2010 | Logitech Webcam
Hi ihave an acer aspire 5600 .My webcam works with other aplications but not on skype and msn.Could you please help me?
Before you can use your webcam in any chat program you have to configure it to that program
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
WINDOWS LIVE MESSENGER ( MSN)
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Feb 09, 2010 | Logitech Quickcam Chat Webcam
My veo camera works, but it doesn't work when i use skype.
working OK ?
CONFIGURE TO SKYPE
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
Start Skype.
On the Tools menu, click 'Options'.
Set your speakers as default.
Click 'Save'
Select your webcam as the default.
Click Save
Dec 22, 2009 | Veo Stingray
Camera won't work...
Its not unusual for webcam software to remain hooked up to a program, even when you exit the previous program correctly.
The answer is to reboot the webcam software by unplugging your webcam from the USB port for a couple of seconds.
Dec 11, 2009 | Logitech QuickCam Deluxe for Notebooks
My audio is not working on my web cam
Hi.
Try first going to Control Panel, then locating Audio Properties.
In there ensure that the default Audio Input device is set to the webcam, and that the microphone is not muted.
Test the camera Audio using Windows , or using the camera dedicated software. Many programs like Messengers, Skype etc. have their own options for Audio.
If you have the problem when using a software, ensure that the software settings are correct.
If none of the above is fixing the problem, try removing the camera from installed hardware list, disconnect camera USB, and reinstall camera drivers.
Restart computer and connect back the camera only when asked, or after reinstalling software and restarting.
Regards.
Nov 10, 2009 | Creative Labs WebCam Live!
My webcams plugged into the usb its a phillips make
If you have more than one webcam software program on your computer you will have to set one as 'default' (nominate the webcam you want to use ) for every program - Skype -MSN - Yahoo Messenger etc.
or
You can uninstall all the webcam software programs from your computer except 1
Sep 04, 2009 | Microsoft LifeCam VX-1000 Webcam
Massive problems with "CREATIVE" WebCam NX Ultra
You have a bad wire ,.. or a "Break" in your cord.
Hence the cam will not work.
I have had the same prob and it sucks!
Buy a new cam.
Sorry
-Smarticus
Oct 26, 2007 | Creative Labs WebCam NX ULTRA
Labtec Webcam
Check the software installation disk. Sometimes these give several programs to run the thing If you install both programs -as I did once- you will get conflicts or none running. Best thing to do is to remove the software and this time take it easy on the install button.
Jul 18, 2007 | Labtec 961307-0914 Webcam
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
