Question about Radio Communications
Constant static my motorola pr400 t way radio makes constant static. and the indicator window indicates that it is always receiving a signal
  • Radio Commun... Master
  • 1,654 Answers
You have one of three issues: 1) You are close to another device transmitting on your frequency, 2) Your radio has a problem and needs service, or 3) You have a low, bad or defective battery.
What you can do:
--Try the radio at a different location to see if the problem is only at a certain location. This will tell you if it is simply interference by another device.
-- Check your antenna for damage, replace if necessary.
--Try the radio with another known good battery and see if the problem goes away.
--If you don't have another battery, try turning it on when in the charging cradle. (NOTE: Do not press the PTT while the radio is on the charger. This can damage your radio. The radio should always be turned off when charging, unless running a simple test such as this one.)
If these do not solve the problem, your radio needs serviced.
Posted on Apr 23, 2009
Clone Motorola BPR40 with PMDN4060AR, but I'm getting a low continual tone from the slave radio from Ch 2 above
Even with a cloning cable, you cannot always clone. The source radio and receiving radio must (1) be the same exact model, (2) have cloning enabled in the software a dealer used when they were programmed the first time. It sounds like you are doing the correct procedure.
Nov 18, 2015 | Motorola Radio Communications
Uniden gmr2638_2ck is always stuck on receive. Rd is always showing and static coming from the speaker
Adjust your SQUELCH control or setting so that the noise disappears. The RX indicator will go out.
Mar 01, 2015 | Uniden Radio Communications
My uniden UH3O5sx is always stuck on receive (rx is always showing) can receive but not transmit
Set up your privacy tones or adjust the squelch level to stop the static and bring the handy out of receive mode. Some models have a busy channel lock out, that if it beleives it hears something it will not let you transmit over the other station.
Oct 04, 2014 | Uniden Radio Communications
Why static on motorola CLS 1110?
Are you referring to static (random snapping, crackling, popping) that only occurs when you are handling the radio, or a steady hissing sound when turned on? The first may indicate the radio has a defect or loose internal connection; the second is reduced by adjusting the squelch setting. More information is always helpful.
Aug 01, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Constant static on talkabout t5320
Could be a sign of a bad battery. Static is a good indicator of a rechargeable battery nearing end of life.
Jan 18, 2014 | Motorola Talkabout T5320 (14 Channels)...
The green light that indicates that some one it talking and goes red when you key always slays on
This is an indication of a receiver problem. Two things cause this. The receiver needs to be realigned or you have bad ceramic filters that need to be replaced.
Sep 12, 2011 | Motorola Mag One BPR40 Two Way Radio
'02 Rendevous beeping randomly, no lights or trouble indicatiors on. Beeps when parked, beeps while driving, no rhyme or reason apparant. sometimes goes 10 or 15 minutes without beeping, other times beeps...
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the left front speaker. The radio receives audible warning requests via the class 2 serial data line from the IPC or body control module (BCM). If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime--200 pulses per minute
Medium rate chime--150 pulses per minute
Slow rate chime--50 pulses per minute
Single chime
Is the sound heard different from typical Audible Warnings ?
Fasten Safety Belt Warning
The radio activates the fasten safety belt audible warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, slow rate and duration (5 pulses). The fasten safety belt warning sounds and the fasten safety belt indicator illuminates when the following occurs:
• The ignition switch transitions to ON.
• The inflatable restraint sensing and diagnostic module (SDM) detects that the driver's seat belt is not buckled, signal is low. The IPC receives a class 2 message from the SDM indicating the driver's seat belt status.
If the seat belt is buckled when the ignition is turned on, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops. If the seat belt is unbuckled after the initial transition to ON, the chime does not sound.
Headlamps On Warning
The radio activates the headlamps on warning as requested by the body control module (BCM). The BCM sends a class 2 message to the radio indicating the chime frequency, fast rate and duration, continuous. The headlamps on warning sounds when the following occurs:
• The ignition is OFF.
• The BCM determines that the driver's door is open, signal is low.
• The BCM determines that the headlamp switch is in the park or head position.
Key-In-Ignition Warning
The radio activates the key-in-ignition audible warning as requested by the BCM. The BCM sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is OFF.
• The body control module (BCM) determines that the driver's door is open, signal is low.
• The BCM determines that the key-in-ignition switch is closed, signal is low.
Turn Signal Reminder
The radio activates the turn signal warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The turn signal warning sounds when the following occurs:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit, left or right turn.
• The vehicle has traveled a distance of 1.2 km (¾ mi) by counting pulses on the vehicle speed input circuit.
The IPC turns OFF the turn signal reminder when either the ignition switch is turned to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits, left turn or right turn.
Additional Chimes
The following chimes will turn ON when an associated indicator/message turns ON in the IPC/DIC:
• ABS indicator
• AWD Disable indicator
• Battery/Charge indicator
• Brake indicator
• Change Engine Oil indicator
• Door Ajar indicator
• Hot Coolant Temp indicator
• Low Brake Fluid indicator
• Low Fuel indicator
• Low Oil Level indicator
• Low Oil Pressure indicator
• Low Tire Pressure indicator/reset
• Low Washer Fluid indicator
• MIL (Service Engine Soon) indicator
• Oil Life Reset
• Park Lamp Out indicator
• Rear Hatch Ajar indicator
• Service Traction System indicator
• Service Vehicle Soon indicator
• TRAC OFF indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation .
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console .
Did the Mechanic check for DTC'S - diagnostic trouble codes in the BCM or insturment cluster ? Did you try a Buick dealer ?
Jul 09, 2017 | 2002 Buick Rendezvous
Constant noise, no squelch, not receiving signal
What you are describing is sometimes called motorboating, and typically indicates the radio needs repair. Without hearing the sound we cannot be certain of your radio's issue. There is also a slight chance you have a battery problem (as in a bad or defective battery). Try a known-good battery on the radio and see if the problem goes away. You might consider contacting the seller to see if they will assist you.
Best regards.
Feb 19, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
My Binatone Marina 300 Walkie talkies give hiss & noise. Pressing menue and up or menu alone makes no difference. How can I have a quiet radio except when called?
Hello andy300,
Does the "RX" indicator show on the LCD screen constantly?
This radio does have a monitor function which disables the squelch control, allowing the user to listen to weak signals on the channel. Enabling this function in absence of any signals will cause the user to hear any background static or noise on the channel. You enable this function by pressing Menu + Up at the same time and disable the function by pressing Menu.
I assume that you are familiar with this function from the fact that you mention these keystrokes have no affect on the radio's behavior.
It is possible that the area you are using the radios in / channel you are using them on has a very high noise level. If the noise level is higher then the radio's automatic squelch threshold, then you would hear constant static, hiss, or white noise and the receive ("RX") indicator would show a constant signal. A local noise level can be caused by atmospheric conditions or very busy nearby adjacent-channel radio signals.
Try operating the radios on a different channel and see if that helps. If it is practical, you might try operating the radios in a different local area just to see if that has any effect at all. This would help you determine if the problem was a local one specific to the area you are operating in.
If it is local area related you might consider switching to a different model of radio that includes a Continuous Coded Squelch System (CTCSS) function (called "privacy codes" or "quiet tones" by come manufacturers. This function does not appear to be included in the model you are using and can help keep your radios silent unless you receive a call from another radio using the exact same privacy code.
If the problem persists regardless of channel or area, then you might have a problem with the radio that would require factory service.
Hope this helps. Best regards!
Ken
Go Ahead. Use Us.
Apr 21, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Radio Communications Logo
236 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
