Question about Hartke Music
Replace transformador toroidal ampli A70 hartke
2 Suggested Answers
  • 7 Answers
SOURCE: where can i find a hartke a70 schematic?
The schematic is here. http://music-electronics-forum.com/attachments/6771d1256866984-a70_sch.pdf
Posted on Jan 11, 2015
I need a schematic diagram with values of components for a hartke gt100 amp
Request the schematic diagram directly from Hartke.
May 23, 2017 | Hartke Music
Hartke vx115 lost significant volume
If you've tried different heads with the same result, the most likely problem is a blown speaker. Check it with an ohm meter, and if it's blown, you can either replace it or get it re-coned.
Apr 24, 2015 | Hartke VX115 - 1 x 15 Bass Guitar Cabinet...
Where can i find a hartke a70 schematic?
Jan 11, 2015 | Hartke A70 70 Watt Bass Amplifier Combo...
Hartke gt 100 no sound led and tube blinks
Perhaps it contains a fuse wich has been blown...or the transformer wich powers the speaker-cabinet
Nov 10, 2013 | Hartke GT100 Guitar Amplifier Head
All three of my tone knobs are snapped off at the pots on my Hartke GT100 head. I wanted to know how I could find the right replacement pots, and how to install them myself.
Finding a parts list would probably require going to the manufacturer. The pots probably have a number on the side. The number is often the model number and the resistance value (encoded) and a letter signifying the "taper". You are probably better to contact Hartke and just order them from them to guarantee getting the right ones.
Sep 14, 2011 | Hartke GT100 Guitar Amplifier Head
HI just got a A70 . I love the amp, except when I hit certain low notes I get a crackle just before the note rings out. Tried 3 new cables same thing , cleaned guitar jack and checked out connections...
You are probably overdriveing the unit... In a 20 foot square room, if *********** could not stand to stay in the room, it is too loud and likely driving the voice coil outside the linear range. This makes a very nasty noise.
Aug 24, 2011 | Hartke A70 70 Watt Bass Amplifier Combo...
My Hartke A100 has a problem, no power, the problem is transformer. what is the exact volt of transformer A100 hartke? than you
Transformers don't often fail. I have heard that some of these have a thermal fuse in them and they sometimes open. If you can get to the fuse in the windings, you can replace it and save the transformer. The fuses look like a silver tube about 5/8 inch long and 3/16 inch diameter with a lead out each end, They are marked with the temp they open and are a one-shot thing that have to be replaced.
May 30, 2011 | Hartke A100 Combo Bass Amp
Looking to buy used bass 3500 hartke,the guy said he hooked up a cd player to it now it doesnt turn on???possibly a power transformer he said??any ideas??thank you
Connecting the CD player should NOT have caused any damage if they were power from the same receptacle and both had grounded plugs OR a walkman type was used which had no external power to it. Power transformers RARELY fail. Check if it has a fuse that has blown BUT do not replace the fuse until the cause of it blowing is found. Switches on a lot of these are POOR and they do fail.
Mar 12, 2011 | Hartke Vx3500 Combo Bass Amplifier * New *
Amps in a seires
I'm not sure what this will do, but electrically you can hook these up. Using the line output from the swx, connect it to the line level input. I think that that would be the active input. When you connect a guitar(without a battery powered pickup) to the hartke, it goes to the passive input right? If so, then connect the line out of the swx to the active input. Reverse if the behavior is opposite of what I described.
Realise that with these two connected to each other, you will be using both pre-amp sections and the amp section of the hartke.
Dan
Mar 01, 2010 | Music
Music Logo
90 people viewed this question
Top Hartke Music Experts
dave nyman
Level 1 Expert
Tom Chichester
Robert Graf
Are you a Hartke Music Expert? Answer questions, earn points and help others
