Question about Apple iPad Complete Display - iPad 3G A1337
How to open i pad a1337. - Apple iPad Complete Display - iPad 3G A1337
It wont charge or turn on
If it wont charge then obviously it wont turn on. The problem lies either with the tablet or the charger. Try a friend or family members charger if that doesn't work then the problem lies with the tablet. You will need to have it looked at.
Apr 12, 2015 | Apple Ipad 64gb 3g At&t Wi-fi Wifi Tablet...
How do I determine what generation is my iPad?
on the backside of the iPad is a model number: determine-generation-ipad-jq4dbyibaqf10wv4m2e43laj-1-0.jpg determine-generation-ipad-jq4dbyibaqf10wv4m2e43laj-1-2.jpg
Model iPad (1st generation) iPad 2 iPad (3rd generation) iPad (4th generation) iPad Air iPad Air 2 Picture 200px-ipad_1_psd_mockup.png 200px-ipad_3.png 200px-ipad_3.png 200px-ipad_3.png 170px-ipad_air.png 170px-ipad_air_2.png Model Number[99] A1219 (Wi-Fi)
A1337 (Wi-Fi + 3G) A1395 (Wi-Fi)
A1396 (GSM model)
A1397 (CDMA model) A1416 (Wi-Fi)
A1403 (Wi-Fi + Cellular (VZ))
A1430 (Wi-Fi + Cellular) A1458 (Wi-Fi)
A1460 (Wi-Fi + Cellular (MM))
A1459 (Wi-Fi + Cellular) A1474 (Wi-Fi)
A1475 (Wi-Fi + Cellular) A1566 (Wi-Fi)
A1567 (Wi-Fi + Cellular How to find iPad IMEI ICCID serial number
http://en.wikipedia.org/wiki/List_of_iOS_devices#iPad
Sep 21, 2014 | Apple iPad Tablets & eReaders
The touch pad on my 10.1 inch asus memo pad doesn't work
Hoe long have you had this tablet? The fix may not be one that can be repaired without opening the case. But I would try a factory reset first.
With this problem, you will need to contact Asus.
Sep 17, 2014 | ASUS MeMo Pad Smart 10
How can i download viber for iPad a1337?
To be able to install Viber, your iPad needs at least iOS 6.0 Apple did not release iOS6 for the iPad 1. So your is running on iOS 4 or 5.
Jul 05, 2014 | Apple Ipad 16gb 3g Wi-fi Wifi Tablet A1337...
How do I get ips6 on my ipad
- this model supports only iOS 5 !
- NO iOS 6/7/8 !
For the iPad first generation (A1219) before iOS 5 to update is only possible with connecting the device to iTunes on a computer. Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
get-ips6-ipad-1y0lj1fh1owk11gcm323dzua-5-0.jpg get-ips6-ipad-1y0lj1fh1owk11gcm323dzua-5-2.jpg get-ips6-ipad-1y0lj1fh1owk11gcm323dzua-5-9.jpg
Jan 11, 2014 | Apple Ipad 16gb 3g Wi-fi Wifi Tablet A1337...
Will not turn on
check the voly out in you vcd adapter if this exist go to open you pad and rebulding soldering the conector volt in and then ready you pad work again please vote
Dec 03, 2013 | ASUS MeMO Pad HD 7
How can I tell if I have an iPad 1 or 2
Here's info from: http://support.apple.com/kb/ht5452
The (original) IPad ...
  • The model number on the back cover is:
    • A1337 on the iPad (Wi-Fi + 3G)
    • A1219 on the iPad (Wi-Fi)
  • Black front bezel
  • 30-pin connector
  • Standard SIM tray on the iPad (Wi-Fi + 3G)
  • The IPad 2 ...
    • A1397 on the iPad 2 (CDMA model)
    • A1396 on the iPad 2 (GSM model)
    • A1395 on the iPad 2 (Wi-Fi)
  • White or black front bezel
  • 30-pin connector
  • The micro-SIM tray is on the right side on iPad (GSM model only)
  • FaceTime and rear cameras
  • Nov 23, 2013 | Apple iPad 64 GB WiFi
    My asus memo hd 7 will not take a charge or turn on whatsoever..How can I fix this..?
    first open your pad check the conector to volt in 4.5v maybe need a rebulding soldering do it then close your pad and work agan vote please
    Nov 04, 2013 | ASUS MeMO Pad HD 7
    My tablet is no power
    How big is the speaker you put the tablet on if it is big enough and the magnets inside the speaker are big enough.Electronics and magnets are mortal enimies if the tablet was to close and the magnets were strong it could wipe out everything on the tablet and stop it from working again ever.
    Dec 22, 2012 | Apple iPad Complete Display - iPad 3G...
    Apple iPad Complete Display - iPad 3G A1337 Logo
    29 people viewed this question
    Top Apple Tablets & eReaders Experts
    Virgil Wolter
    Level 1 Expert
    Aaron Galvan
    Level 1 Expert
    John mullen
    Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
