Question about Bosch Classixx WFL 2066 Front Load Washer
Cant connect the water hoses the machine
Bought bosch,classixx,1000 washing machn,but cant connect a second water hose hose behind to start using it,can someone provide me with a manual that has the connection diagram cos i feel that a part is missisng.
  • Barry Coates
    Barry Coates May 11, 2010
    Has it got 2 hose connections at the rear of washer, or just one connection?
    President:
  • 1,185 Answers
Cold fill only , designed to run efficiently on lower temperatures and with cold water powders
Blank off the hot supply line at the back of your washer before you fit it back to the wall.
Only two pipes on the machine Cold In, Waste out
Posted on May 24, 2009
I have a Bosch classixx 1200s Expresss. When I press the start nothing happens and a get a 12 beep alarm (4 then 4 then 4) every 60 seconds. There is power and water
I'm not an expert. I just had the same error (on a Bosch Maxx 6) and fixed it by chance.
My area has a lot of debris in the water supply, and it turns out that the small filter in the hose connected to the water supply was completely clogged up. You can either replace this filter, or clean it as outlined below.
Here are the steps to cleaning it:
1) Unplug washer
2) Turn of the water supply, either by a turning the handle to the washing machine water supply or by turning of the water main.
3) unscrew both ends of the water supply hose
4) Screw the washing machine end of the water hose into the water supply outlet
5) On the other end of the hose, there is a small filter. Hold this in place with the tip of your finger, and turn on the water supply for a few seconds, while keeping the free end of the hose in a bucket. This will flush water through the filter in reverse, thereby cleaning it. Do NOT reverse water flow with one end still attached to the washer machine, as this will flush all the debris into your machine!
6) Turn of the water supply, unscrew the water hose, and reconnect both ends as specified by the manufacturer.
Hope that helps!
-Dennis
Apr 07, 2011 | Bosch Classixx WFL 2066 Front Load Washer
I have a bosch classixx slimline dishwasher when I use the quick wash the tablet doesn't dissolve. Is ther any solution to this problem
Check your inlet water flow to the machine. Clean the filter at the machine end near the flexible hose connection!
Sep 15, 2010 | Bosch Dishwashers
My Bosch Classixx 1200 has stopped rotating. The electronics seem to work, the machine fills with water and drains water away, but the drum stays still. It can be rotated by hand and the drive belt is...
Check the exit hose behind the machine, the one going into the standpipe. This should be around 3 feet up from the ground level, and then into the standpipe. It shd be about six inches into the standpipe & not too tight into it.
This hose may have fallen off, the reason why your water drains away, instead of collecting in the machine to commence a wash. The next to check is the thin tube coming up from the pump area to the pressure switch. Maybe this has come loose or there is a puncture in it.
Pl give me a good rating for the free help, if helped ie.
May 18, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My bosch classixx 1200, my washing machine leaks when not in use, to solve the problem i have had to have a valve fitted to the pipe that feeds water into the machine and keep switching the valve down to...
Remove top and check that they are your fill vaulves. Your hoses should be connected to them if so.If they are leaking on inside of machine when off then they need replacing.
Mar 15, 2010 | Bosch Classixx WFC 2465 Front Load Washer
The outlet hose on my classixx 1000 seems to have a blockage
FILL DRUM WITH HOT WATER FROM A JUG SHUT DOOR AND PUT ON SPIN REMOVE HOSE FROM OUTLET AND PUT IN BUCKET OR SINK ACTIVATE SPIN AND SHAKE AND STRETCH THE HOSE VIGOUROUSLY THIS WILL SHIFT DEPOSITS KEEP DOING IT TILL WATER RUNS CLEAR MAKE TAKE A WHILE.
Jul 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch SRS4302GB Replacement Inlet hose - which type?
it should have and is delivered with the narrow bore high pressure hose
if your water flow rate is high more than 20 ltrs p min you could get away with a standard low preessure hose
you can download the instruction manual from the bosch web site or from the bsh home appliances web site
good luck
Mar 06, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch Classixx 1000 Express washing machine won't fill with water
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch WFL 2462
Your exit hose behind the machine has to go over a certain height before it goes into your wall standpipe or sink. The height is marked behind your machine, approx 3 feet above ground level. The hose should put about 3 or 4 inches into the standpipe, & not fitted airtight.
Possible u didnt connect well after your pump job or ........
May 02, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Bosch Classixx 1000 manual
usually it is the larger for the main powder the second largest for the prewash powder and the smallest (labelled with a "max line" for the fab conditioner) the calgon can go in with the main wash or be put straight in the drum.
May 27, 2007 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
300 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
