Coleman evcon heater and fan run continually since we replaced the transformer
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Posted on May 30, 2008
  • 6 Answers
SOURCE: coleman evcon Dgato7obdc
Small blower motor? Are you talking about the combustion blower if so then check your vents for blockage.. if the vents are blocked won't work... if it has a control board init it will give you a diagnostic code. Flashing light on the board... count the flashes and look up the fault on the chart in your owners manual ot on the furnace door..
Posted on Jan 15, 2009
  • 92 Answers
SOURCE: gas furnace for mobile home, Coleman DGAM056BDD,
Is your thermostat set to on?That would make it run continuously.There is a relay in the Coleman unit that could be stuck. Good luck--
Posted on Sep 10, 2009
  • 221 Answers
SOURCE: Coleman Evcon (DGAT070BDD) fan kicks on but only
Your unit definitely is on a recall list. Go to http://www.dgatprogram.com/
Posted on Dec 31, 2009
  • 221 Answers
SOURCE: Coleman Evcon..... Inducer Adjustment
Just wanted to make sure you knew this model is on a recall list:
Posted on Jan 02, 2010
I have a coleman evcon model eb15a furnace. it does not work with the therostat, if you turn the main breakers on the fan and one elament come on the fan auto/continuious run switch doest work either any...
Hello, have you tried jumping the R and W wires on the thermostat sub base? If this turns on you furnace than the thermostat is bad, however if there is no display on the thermostat and does not power up by jumping the R and W Wires then most likely the transformer is bad and must be replaced.
Mar 16, 2011 | Coleman Heating & Cooling
I have a coleman evcon electric furnace ,it was running and would not cutoff the heat got up to around 90 thhe thermostad said it was running in aux ,so I turn the main breaker off and the in a few minute...
If the thermostat is ok which it probably is then your sequencer is most likely stuck i would say. You could verify that by removing 24 volts to the sequencer to see if it will shut down the heater
themobilian_598.jpg When low voltage from the thermostat is applied at the base of this sequencer it heats a bi-metal and turns on each coil and fan in a sequence that will insure the breaker don't throw from the power surge AND warm air comes out the vents when that fan comes on. I would start there.
Dec 28, 2010 | Coleman Heating & Cooling
We have a Coleman Evcon BW-305150. Last night we
There should be one right above the burner tray. Look at the wiring diagram (pasted on one of the panels) and follow the wires Usually red orange or yellow) to the switch (may look like a rectangle plate with 2 prongs) and jump the switch with a jumper to test.
Feb 26, 2010 | Coleman Propane Forced Air Heater...
Draft fan keeps on running after furnace shuts
That sounds pretty normal for most furnace/heater products. They run the heating element with fan for a cycle then after the heater reaches temperature it will shut off and the fan will continue to run to cool the element and to circulate the heat that it produced. If you want the manual for this product it looks like you can get it here: http://homeappliance.manualsonline.com/ex/product/headline/m/Coleman%2BEvcon/d/furnace/p/DGATO75BDC
Oct 26, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
I have a coleman evcon dagto7obdd fan keeps running i changed the limit switches fan keeps running and 4 blinking lights means limit open
Check for continuity through all your switches. Check voltage where these switches hook up to your control ignition box.if you see voltage there the problem is either the wiring or one of your switches is open. If you read no voltage there check again from "C" to the same wires a readign then indicates a bad board. Then check "R" to there a reading here indicates a bad thermostat (which is probably not your trouble due to the code and your legend of the code 4)
Hope this is cleaR and helps Please grade am accordingly and good luck.
Mar 08, 2009 | Coleman Propane Forced Air Heater...
Coleman Evcon furnace, blower runs continuously even after the temp has been reached.
make sure the thermostat is in the auto mode if so it is more than likely the fan relay control some are built on the board some can be replaced separately
Dec 16, 2008 | Coleman Propane Forced Air Heater...
Carrier (outside) Coleman Evcon (inside) Air Conditioning question
transformer has just 4 leads. 2 for primary which is your 110 volts and 2 for secondary which is supposed to be 24 volts ac. if you splice the two secondary wires coming out of your transformer, you should be able to get a 24 v ac there.
the box that you are referring to could be a fire controller that in case of fire, it would shut off the fan and the compressor outside.
tnx 4 using fixya,
drcool
Oct 01, 2008 | Heating & Cooling
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
10 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
